Old 05-01-2019, 04:52 PM   #1
Anderson Level blocks
Hello has any used these to help stabilize your 5er?. We have a Cedar Creek 36ck2 and wondering if they would make a difference
jmcclocklin is offline   Reply With Quote
Old 05-01-2019, 08:01 PM   #2
Yes I wouldnít leave home without them. They are very easy to use, I use them on the jacks around the tires nearly every time. The front jacks are a little more tricky because of the level adjustment, Your trailer would have to be on a serious front downslope site to need them there. I bought 4.
Highly recommended!
MikeRP is offline   Reply With Quote
Old 05-01-2019, 08:03 PM   #3
Thank you I was thinking I would need six so thanks for saving me some $$
Old 05-02-2019, 09:50 AM   #4
Jim34RL's Avatar
To me they are a waste of good hard earn $$$$. Why? They are of a fixed height and plastic so, they will deteriorate over time. I have never needed 8" of pad height for my needs I usually get by with 5" tall in he front and 3" under the other stabilizer legs on my Cedar Creek.
I use wooden blocks and boards of various thickness for my needs. The blocks are cut 4X4X12" long and the boards are 2X8X12". I also carry two packs of the plastic Lego style leveling pads. This way I can achieve the proper height I need before extending my legs all around.
Just my $0.02
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 05-02-2019, 10:31 AM   #5
at 45.00 each that's a bit pricey. do they stack like a bucket? That would be nice, otherwise a wood block or the legos work fine for me.
I do like the leveler though, need to get a second one, they work well for small adjustments and if the ground is loose where blocks will slide.
nayther is offline   Reply With Quote
Old 05-02-2019, 09:49 PM   #6
dieselguy's Avatar
I understand you wanting to reduce the cylinder extension to help reduce movement with the Level Up. The price and not being able to totally fit one inside another thus taking up room nixed the purchase of the Anderson Levelers for us. I carry about eight 2X8"s cut to about 16" long in my truck toolbox ... works for us and saved $$$$.
dieselguy is offline   Reply With Quote
Old 05-05-2019, 01:09 PM   #7
BuzzWolfAR's Avatar
I bought 6 but only use 4. Absolutely live them. Easy to store, clean and work great. As was said before, I wouldn't leave home without them.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 05-05-2019, 01:47 PM   #8
I use six 6x6s, each about a foot long. I have attached cabinet handles, which makes it easy to pick up to carry. I used them regardless, so as to avoid a potential stroke error.
They work great.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 05-05-2019, 06:33 PM   #9
Derek10's Avatar
Just picked these up and they work like a charm. They stabilize the 5er as well as save travel on the cylinders. Made fro very heavy duty plastic that will probably out last anyone in here.
2018 Ford F350 Diesel
2019 Cedar Creek 33IK
Nights Camped 2015=30, 2016=27, 2017=43, 2018=62
Derek10 is offline   Reply With Quote
Old 05-05-2019, 08:34 PM   #10
Here in Canada they are not cheap, best price I have found is $75.00 each. So I am thinking of using 2x10 and some thick plywood and build some.pads. Thanks for all the replies.
Old 05-05-2019, 08:59 PM   #11
Derek10's Avatar
I just bought a six pack. https://parts.pjcanada.com/products/...k-block-6-pack Delivery included. Not $75 each either.
Old 05-05-2019, 09:38 PM   #12
Why are you worried about travel on your cylinders? Thatís what they are made for. I made ten inch square pads by using 3/4 inch plywood and glued 2 of them together and screwed them to each other also.
Okie Dokie 2 is offline   Reply With Quote
Old 05-05-2019, 09:47 PM   #13
Derek10's Avatar
Why would you not be worried? Less travel=less damage, less travel means less dust a debris that can attach to the cylinder. Less travel also makes for a stable unit when camping. Just my humble opinion.
Old 05-06-2019, 07:35 AM   #14
They are pricey but they are prefect for the rear of the Coach. I have yet not to use them on the 4 around the tires. I can stack all 4 in my storage are but I usually do two on one side and two on the other.
Old 05-06-2019, 07:38 AM   #15
Also in my crash in Key Largo, update coming soon. The trailer stayed on the blocks. The front moved about 16 inches left off the stackable blocks I use in gravel areas.
Old 05-08-2019, 06:08 PM   #16
Old Bleu's Avatar
We have 4 of these and love them. We only use them on the rear jacks since they were too tall to use in the front with the auto level. The magnets make them very easy to attach, and the coach is very stable with the jacks just partially deployed. We stack two on each side of our pass through storage bay. If Andersen made a shorter version, we would use them on the front landing gear as well.
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
Old Bleu is offline   Reply With Quote
Old 05-09-2019, 03:13 PM   #17
I have a question for those that use these. I just use jack pads and find quite often the ground is not level at all and the pads are on an angle such as when right on edge of gravel and grass. How do these hollow, open bottom level blocks hold up to all the weight when at an angle? Also seems that you would have to put pads under them if not on concrete site? I really like the idea and if they were half the price would just buy them to try out.
cub22908 is offline   Reply With Quote
Old 05-09-2019, 04:19 PM   #18
BuzzWolfAR's Avatar
I've never been in a situation where they couldn't work. Probably only have 30 days of use, but the haven't worn at all.
Buzz & Jo Wolf
Old 05-09-2019, 05:36 PM   #19
Old Bleu's Avatar
We have only had ours since last fall, and have to say that we have not encountered a site yet that was not fairly level. Maybe the high side of the leveler would sink in a bit to reach a more level state. We still carry a coupe bags of the Lynx levelers, but have not used them since we got the Andersen blocks.
They are kind of expensive, but appear to be well made and I see no signs of wear on ours yet. I like that they're easy to clean off and stow. When we get to a site, my wife pops the two on the curb side and I do the street side, then we hit auto level and we're done.
Old 05-09-2019, 05:49 PM   #20
Piece of wood would be better but may weigh more. I personally never put anything down between the stabilizers and the dirt unless the ground is soft or I am on asphalt and its hot. I would rather have a slight amount of conductivity between my trailer and the ground although it may be minimal.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
lock
