Old 05-27-2013, 08:57 AM   #11
VinceU's Avatar
Originally Posted by Bill Howard
Interesting comment about the extra fans. I'll be mulling over that one while I find out what dealer/Dometic can or will do. The annoying noise is definitely the fans - mechanical in nature at very high pitch. Air flow I could probably live with. Any idea how Dometic exhausts the air and/or where, into what? Wonder if that might help. ...the continuing saga...
Fan(s) are attached to back of reefer box and temp controlled with a thermostat. Sole purpose is to direct air from lower louvered vent opening into the condenser coils and exit at the roof. Added fans easy to access, orig must remove fridge most models.
