Old 08-30-2016, 10:19 AM   #11
NMWildcat's Avatar
Originally Posted by BandJCarm View Post
OK, I'm sold on the concept.
I can't answer WHY exactly, but I like the SteadyFast better. Regardless, I am hearing from others that it can't be done on the 6 Pt Leveling System (even though SteadyFast website has specific model for that), and 2nd that welding is required. Not a deal breaker, but i'd have to find a welding shop.
Is there really some big difference between the two? Everyone that has EITHER Loves it.......so no buyer's remorse appears to be evident either way.
I liked SteadyFast better as it has fewer mount points to attach to your rig and you can't lose the tightner. Strongarms has a T handle that everybody seems to lose at some point. Also SteadyFast just looks cleaner to me. Just my opinion. If you missed my first post you don't have to weld, and they do work with 6 point level ups. Call them.... they are a pleasure to work with.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-30-2016, 10:23 AM   #12
BandJCarm's Avatar
I did miss it....it was being posted when I was in and out, I'm sorry! No slight intended.
I have one worry I guess. Even the installation instructions for the bolt on kit say that the BEST way to put the bolt on the round footplate is to weld the bolt head on!! The drilling instructions require some special tools that I don't have. And.......welding WOULD be better I'd think.
Still, I'm being told by other CC folks that it can't be done.
I can't find a single model of what I have, specifically, that has done it. There's no CC models in the SteadyFast pictures or examples. I'd sure feel better if someone with my unit (there's a million of 'em) has done it.
Will check back later.........
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 08-30-2016, 10:39 AM   #13
NMWildcat's Avatar
I understand your concern. I had the some ones! So I called them (SteadyFast) and they answered all my questions. They might have even done some CCs. I would like to hear why CC folks say it can't be done. Just curious. I've already scoped out the best mount points on my frame. I will order mine with the bolt kit for the level up as soon as the boss tells me I can Seems like doctors bills take priority?
Old 08-30-2016, 11:24 AM   #14
Jim34RL's Avatar
Ok I am the doubting Thomas on these type of add on devices.
Why?
Will you have to weld on the frame and or drill into the frame! Being a retired structural engineer I am afraid of aftermarket welding taking place on an I-beam type of frame.
One; there should be no transvers welds on the frame; this will induce cracking and or fatigue weld failures on the frame.
Two; what type of weld rod will the welder use on the frame will it be compatible to the frame material? Steel is not steel when you use I-beams for framing. Different types of material grade and alloys to make up this steel can be used when designing the frame. With different types of fatigue life that the welding can effect. You might need to pre-heat and or post heat the frame to reduce the weld stress that can be introduced. This too might effect the hydraulic ram material when welded!
Three; will this weld penetrate the parent material and be structural sound weld or just slag deposit?
Now drill brings a whole new set of problems when drilling into an I-beam frame. Where will the drilled hole be place near the edge and or in the web of the I-Beam. These type of holes may lead to fatigue stress of the frame and crack it over time.
Why do you think you need the stabilizing supports?
Do you extend the hydraulic rams to their full length? If so try to shorten up the ram extended legs; by placing Lynx Level pads or wooded blocks under the ram legs. I use between three and four pads under the rear legs. On the front legs I like to spread out the weight of the fiver by using a 2X8X12" long and two 4X4x12" long cedar post screwed and glued to the wooden board.
My wife has never complained about me walking around in our 34RL when we are set up.
You can also install two X-Chocks between the wheels for additional stability if you think you needed it.
Also remember you will need to cut away the outside wall wrapper that covers the frame on your Cedar Creek. This too may cause you issues down the road.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, 100K+miles
Jim34RL is online now   Reply With Quote
Old 08-30-2016, 11:30 AM   #15
TURBS's Avatar
The drilling occurs on the i beam flats no on the web.
My mounts were pre installed by lippert and welded.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 08-30-2016, 02:15 PM   #16
Had the JT Strongarms on my last 5er Made a big difference. I installed them in a few hours. No welding or strange tools needed. Highly recommend JT.
Don't have them on my current Coachman since the 6 point system is handling things rather well.
ottawapaul is offline   Reply With Quote
Old 08-30-2016, 04:04 PM   #17
Herk7769's Avatar
I put these on. Sold by http://winfieldrvproducts.com/landin...tabilizer.html
They work great; take about 15 minutes to install with no drilling.
HAM CALLSIGN - KC3FFW
Old 08-30-2016, 08:23 PM   #18
I purchased the steady fast system for our 272 bhs vibe although we don't have the 6 point leveler system it was a breeze to install and most definitely works takes out 90% of the bounce and movement . Extreamly happy with it.
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 08-30-2016, 10:47 PM   #19
JTs
wife asked me to get something to stop movement in front of 5er. tried the tripod, just OK. bought JTs and put them only on front. very good. now will move onto the front sides and rear. I think they will be great
very easy install.
NOW do not forget to loosen the bolts before retracting.
bbaker2001 is offline   Reply With Quote
Old 08-30-2016, 11:13 PM   #20
Mrs Evans's Avatar
Bookmarking this company - nice option! Thanks for sharing
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
led
