Old 05-17-2013, 10:51 PM   #1
BoatDude's Avatar
Anyone with a residential refrigerator
Anyone have a smart fix to keep the refrigerator door from hitting the counter top when opening. Our door slowly keeps moving intil it hits the counter top.
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 05-18-2013, 06:35 AM   #2
Hey BoatDude, Maybe it is the calibration of your level up system. Ours does not do that.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 05-18-2013, 06:46 AM   #3
Tie a string on the bottom.
Old 05-18-2013, 01:05 PM   #4
BoatDude's Avatar
We check the level up system...the coach is level. It may be the levelers on the bottom of the refrigerator itself. its just a home frig..maybe I can get to the adjusters in the front and make the frig better on level. A bullseye level in the frig shows a very slight out of center level. I keep tweaking it. To bad a stop is not built into the frig hinge.
2013 36 CKTS
ReTrax Pro Cover
Old 05-18-2013, 02:09 PM   #5
Phat Phrog Stunt Crew
awwall's Avatar
Maybe level a little off level in the direction to keep door from moving...
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-18-2013, 02:57 PM   #6
Get creative and put a stop cable on the bottom of the door.
Old 05-18-2013, 06:50 PM   #7
I adjusted my RV for a level stove and calibrated the Level Up System for that set up. The end result...my refer door does not move. If I leave it open, it will stay that way. Usually, I like a refer that swings the door closed when you let go of the door. I might have to jack up the front a bit.
Old 05-19-2013, 08:45 PM   #8
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
My CC 36CKTS has the same fridge with the same problem. I put a small self adhesive bumper on the edge of the counter top and I don't loose any sleep over it now. When I pull over for lunch I sure as heck don't check level either!
Travel safe & enjoy the ride!
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
