Old 05-17-2019, 10:56 AM   #1
TexasGolfBum's Avatar
Auto Level
Is it hard to calibrate the leveling on our 2012 Cedar Creek 5th wheel? Once level it still tilts to one side. Not a real smart guy here and without a manual I don't have a clue where to start. Should I spend the money and have the dealer adjust it?
TexasGolfBum is offline   Reply With Quote
Old 05-17-2019, 11:13 AM   #2
It should be level so there is some type of issue? Is it the six leg system?
whj469 is offline   Reply With Quote
Old 05-17-2019, 11:16 AM   #3
Yes it is. Not off a whole lit but enough to have the eggs and refrigerator door go to one side.
Old 05-17-2019, 11:24 AM   #4
NMWildcat's Avatar
https://www.lci1.com/support-master-manuals
Find your leveling system in this master manual. Level-Up starts on page 241. Go to the zero point calibration section to find step by step instructions for your particular system. It really is easy to do. First, use manual level to get your RV just like you want it. Then follow the zero point calibration steps. The next time you auto level it will go back to this zero point you just set.
Good luck and enjoy!!!
Scott and Liz - Southern NM
Old 05-17-2019, 11:40 AM   #5
Thank you.
Old 05-18-2019, 03:48 PM   #6
Yes as above. You should have a manual from Levelup that has more detail or where to contact them.
Old 05-18-2019, 05:13 PM   #7
The link would not load.
Old 05-18-2019, 05:17 PM   #8
BandJCarm's Avatar
Level Zero Point Calibration
Before auto leveling features are available, the Level Zero point must be set. This is the point to which the
system will return when an auto leveling cycle is initiated. To set the zero point (controller module must be
fully secured in production intent location), first run a manual leveling sequence to get the vehicle to the
desired level point. Then activate the Level Zero point configuration mode.
This mode is enabled by performing the following sequence:
1. Turn panel off. Then turn panel on.
2. Perform the following:
A. Press the Front switch 5 times.
B. Press the Rear switch 5 times.
3. At this point all LED outputs will blink, and the buzzer will be off.
4. You are now in IDLE mode ready to set Zero Point.
5. With a carpenter’s level, manually level the coach. This will give the leveling controls the reference
point for the Zero Point Configuration.
6. When coach is completely leveled, manually press the Retract All switch 3 times to set the zero point.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 05-18-2019, 06:05 PM   #9
Thank you for this information. Big help.
Old 05-18-2019, 07:19 PM   #10
NMWildcat's Avatar
You still need the routine for your particular system. There are several different ones. The one above won't work for my 6point level-up, but might work for yours. Just do an internet search for lippert level-up manuals if the link won't work for you. All the manuals are online and you can identify yours by the pictures or model if you know it.
Let us know what works for you so we can all learn. Good luck!
