Old 06-30-2019, 03:52 PM   #1
Auto leveler
My auto leveler does not have power to it so I can raise my stablizers. I have a Silverback 33ik. Is there a manual way to raise them?
Ebosco33 is offline   Reply With Quote
Old 06-30-2019, 03:58 PM   #2
n1joh's Avatar
Follow your wiring from the pump it sounds like you blow a circuit breaker. You should see a power strip and put your finger behind it and you should feel the reset.
n1joh is offline   Reply With Quote
Old 06-30-2019, 04:06 PM   #3
n1joh's Avatar
Not a ac reset. It's a 12 volt reset
Old 06-30-2019, 04:10 PM   #4
I have a 33IK. Sounds like you tripped the mini breaker. It is in the front basement behind the round panel on the right. Move the panel and you will see what looks like a buss bar but it is actually a row of breakers. Look on the left side and you will,see the small black buttons. Press them to reset. See pics below. Sorry about sideways pics..
ID:	208601   Click image for larger version
ID:	208602   Click image for larger version
2016 Siverback 33IK
Old 06-30-2019, 04:55 PM   #5
We have a 2019 silverback 33ik. Ours does not have a reset button...has an auto reset. When our stabilizers did the same thing we had to get a new motor for the hydraulic pump. If it is the pump motor,you need a high speed drill to raise or lower the landing gear. Not an easy task. Suggest calling your dealer for directions. Just got it home a couple days ago. Thankful for warranty!
2019 Forest River Silverback 33iK
Ford F350 tow vehicle
SW Pennsylvania
Member Travel Resorts of America
Retired and adventurous!
Bbfish is offline   Reply With Quote
Old 07-01-2019, 06:47 AM   #6
On my Riverstone , there was a 50 amp non-resettable breaker (now replaced with an 80 resettable). If it is indeed a bad breaker, you can jump it with a screwdriver or wire.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
