Old 05-12-2014, 07:47 PM   #11
Todouble's Avatar
Thanks for replying with the end result. Many people don't follow up and we never know how things turned out.
Todouble is offline   Reply With Quote
Old 05-12-2014, 08:00 PM   #12
Sewhappy's Avatar
It started to lock up when we tried to auto level again but this time we stopped when it started to make a grinding noise. Our parking place for our CC 36 ckts, is on a slight slant side to side. So we used the manual mode. Until we get the site level, the manual mode is what we will use. They should really tell you this information during the PDI. And they should definitely show you where the reset is since it is hidden and none of the paperwork mentions this. In fact Lippert gives you this big booklet but nothing about troubleshooting and their web site is useless.
There are so many things that you have to learn when you purchase your first camper. This forum has educated and helped us so much.
Thank you to all!
Sewhappy is offline   Reply With Quote
Old 05-12-2014, 08:36 PM   #13
Former Full Timer
Duckogram's Avatar
Originally Posted by Sewhappy View Post
Well we took it to Tom Johnson today and they showed us how to reset it. It seems there is a gray button that you would never know to push in the front basement. Now we know! Glad it was an easy fix.
That's great. Glad I was wrong.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 05-13-2014, 07:01 AM   #14
I have a Lippert system on mine also it has worked flawlessly so far but...... Where is the grey reset button located is it on the backside of the controller or where? Inquiring minds want to know
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 05-13-2014, 08:54 AM   #15
What I found about the levle up 6 point system is it likes to extend up to .2 degree above and below level. If it cannot make that range due to grounding the jacks or cannot extend any further it locks up. It has changed my habits about leveling at sites, sometimes just a foot in either direction can make a huge difference, other times the extra 12x12x2 blocks come out to give the level up the range it needs to do its cycle (and yes boards under the wheels that will likely end up off the ground.
jbrostek is offline   Reply With Quote
Old 05-13-2014, 09:02 AM   #16
Oakman's Avatar
X2. That info could be useful to some of the other members with that system.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-13-2014, 09:07 AM   #17
Plain Old Member
Sewhappy, mind taking a picture of that reset button and posting? Probably in a similar location on the SB. I'll be looking when I get ours back.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-13-2014, 09:56 AM   #18
Sewhappy's Avatar
I will try to post a picture this evening of the reset.
Old 05-13-2014, 04:51 PM   #19
Sewhappy's Avatar
Relays are located in a compartment behind the hydraulic pump which is behind a board in the front basement. Reset buttons on the relays are unmarked and not easily recognizable as a reset button. In the photos we added labels pointing to each reset. They are tiny little black spring loaded rubber buttons on the side of the relay block. Push and release each one and your hydraulics work again. Remember this how it is on our CC36 CKTS. We have the Lippert 6 way Auto Level.
Hope this will keep someone else from spending hours trying to figure it out and a trip to the dealer.
ID:	52331   Click image for larger version
