Old 05-10-2014, 05:06 PM   #1
Sewhappy's Avatar
Auto leveling locked up
So we park at our house and the Lippert 6 way auto leveling system is locked. After selecting Auto level, on a slight incline side to side, The front jacks fully retract and the pump continues to run. The whole system cut off. Pump will not come back on. The manual says to turn the power off and then back on. Does anyone know where you do that? We have looked everywhere except where it is. It is not the big red key in the water compartment and main breaker did not reset system.
Sewhappy is offline   Reply With Quote
Old 05-10-2014, 05:32 PM   #2
Former Full Timer
Duckogram's Avatar
No, you need to turn off the power to the computer to reset.
I suggest you pull the plug on the back side of your control panel.
That should get it done. or, you can turn the control panel off then on and enter
manual mode.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 05-10-2014, 07:37 PM   #3
Sewhappy's Avatar
We will try that in the morning. My DH used a drill to manually lower the legs. Are you saying that we should unplug the control panel for the leveling system?
Old 05-10-2014, 08:07 PM   #4
Todouble's Avatar
Could be a blown fuse as well.
Todouble is offline   Reply With Quote
Old 05-10-2014, 08:10 PM   #5
Yes for unplugging the control box - the Levelers get battery power before the cut-off switch.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-10-2014, 08:10 PM   #6
VinceU's Avatar
Two ideas for you.
Turn on keypad on/off button press and hold all four diamond keys front back and both sides for about 10 secs. Soft reset.
If that fails remove battery cable + or - again for same 10 secs.
One or the other should reset the computer unless something failed.
Old 05-11-2014, 11:19 AM   #7
Sewhappy's Avatar
Well we have tried all of your suggestions and no success. Tomorrow, I will call the dealer. It's a shame. We have it just about a month. Could be worse. At least we're home when this happened.
Old 05-11-2014, 05:38 PM   #8
Former Full Timer
Duckogram's Avatar
Sorry nothing worked. Please let us know what the mŗlfunction was after the dealer fixes it. My guess is defective control board...
Old 05-12-2014, 07:44 AM   #9
Lippert system
On my Silverback they installed a breaker in the front storage compartment. This turns the lippert on and off.
bgant4 is offline   Reply With Quote
Old 05-12-2014, 03:43 PM   #10
Sewhappy's Avatar
Well we took it to Tom Johnson today and they showed us how to reset it. It seems there is a gray button that you would never know to push in the front basement. Now we know! Glad it was an easy fix.
