Old 07-31-2013, 03:43 PM   #1
Awning, slide, levelng and light remote
My Cedar Creek remote for the awning, etc. has stopped working. The battery in the remote seems OK and the lights on the remote light up but nothing happens. I think maybe something might have happen while at the dealership earlier this year. I was going to check to be sure it didn't loose it's memory, but I can't find the relay module per the instructions on the remote. Anyone have any ideas where the relay module might be located on a 2013 CC 36CKTS Touring Edition?
Steve & Lee
Jacksonville, FL
2013 Cedar Creek 36 CKTS Touring Edition
2012 F350 King Ranch, Reese Elite 18 and Air Bags
Elkrun is offline   Reply With Quote
Old 07-31-2013, 06:03 PM   #2
Call the service department at your dealership. They should know how to reset it.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 07-31-2013, 07:13 PM   #3
Former Full Timer
Duckogram's Avatar
Open the front garage and pull back the plastic shield on the right side. On the rear bulkhead you will find your relays and fuse box for everything that is independent of the power distribution panel. On the panel there is a button and yellow indicator light.
Follow the instructions on the bulkhead or backside of the remote to reprogram your remote. Hope this helps.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 08-01-2013, 07:57 AM   #4
Thanks Ducky, I checked there once but I'll do a more through search later today.
Steve & Lee
Jacksonville, FL
Old 08-01-2013, 05:37 PM   #5
I found the relay module per Ducky's instructions. The yellow light is not on and when I push the button above the light it does not flash. The relay module may be bad or if it is fused that may be the problem. I assume that the yellow light should be on..........is this correct?
Steve & Lee
Jacksonville, FL
Old 08-01-2013, 06:47 PM   #6
Former Full Timer
Duckogram's Avatar
Elkrun,
The yellow light does not stay on. The receiver goes into a power saver like mode. In order to program the transmitter to match the receiver you must push and hold the button until the yellow light flashes. Follow these instruction exactly:
Old 08-02-2013, 07:04 AM   #7
Thanks Ducky, those are the same instructions that I have. Maybe I didn't hold the button down long enough. I'll try it again and we'll see what happens.
Steve & Lee
Jacksonville, FL
Old 08-02-2013, 11:45 AM   #8
Ducky,
I depressed the white button over the yellow led several times and held it depressed for over a minute and the yellow light never started to blink. I think there may be a problem with the relay module.
Steve & Lee
Jacksonville, FL
Old 08-02-2013, 05:09 PM   #9
Former Full Timer
Duckogram's Avatar
Try using a pencil with an eraser on the end. Sometimes it is hard to get the button to push straight in with a finger. It takes quite a while to get the light to flash so your finger might get tired before you achieve success...
Old 08-02-2013, 05:33 PM   #10
rattleNsmoke's Avatar
Tired fingers are not good...*s.
rattleNsmoke is offline   Reply With Quote
awning, light, slide
