Old 01-07-2016, 07:09 PM   #11
tmfaulksr's Avatar
Originally Posted by bob caldwell View Post
Have you try'd jump'n switch? I put a remote control on this one so don't now use wall switch......can be outside to operate
is there a simple way to explain how you added a remote to your awning
switch assembly inside the RV? it would be greatly appreciated by me if
not by many more.... thanks in advance
tmfaulksr
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
tmfaulksr is offline   Reply With Quote
Old 01-07-2016, 07:31 PM   #12
Left Coast
It's POUR'N here right now, but I'll post a piv of the unit when I can get it out or storage area. There was a thread called lazy man awning....might look in the library section of forum and see if it's there...Box (controler) was RM66...now there's a newer better one that I've got and hopefully still have the part num. Also, it uses a key-fob
Old 01-08-2016, 11:07 AM   #13
Left Coast
New model controller is RM 800.....12V DC 2-Pole motor relay switch. No name of course, so you'll need to Google it
Old 01-08-2016, 11:16 AM   #14
TURBS's Avatar
tmfaulksr
Poor mans Awning Remote Help
All you needed to know and more.
lazy man's power awning mod .
Read second link first and 1st link last.
Sent from my SM-G900R4 using Tapatalk
Old 01-08-2016, 11:50 AM   #15
Originally Posted by phillyg View Post
Had put out our Dometic awning perhaps five times since new. Wouldn't go out last trip. Motor had to be replaced.
Do check your motor in the tube for heat. Some burnouts are caused by constant 12V bleeding past the rocker switch. Motor should be cool to the touch.
Old 01-17-2016, 11:02 AM   #16
Cato's Avatar
Awning motor has been replaced (using FR extended warranty!)
Dick Gore RV in St Augustine Fl
Great service.
Cato is offline   Reply With Quote
Old 01-17-2016, 03:03 PM   #17
Glad to hear that Cato. I'm a little leery of recommending a service fearing they may not treat someone else as good as they do me. Very pleased that Dick Gore in St. Augustine did not disappoint either one of us. IMO they are very good to deal with. Thanks for the follow up & that your problem has been taken care of.
Papa GLS is offline   Reply With Quote
awning
