Old 10-04-2015, 06:31 PM   #1
steelpony5555's Avatar
Back to the stinky slinky storage problem...
I know since the engineers who designed the storage bumper for the sewer hose forgot to bring his measuring tape to work that day, I must now become creative. I know most folks use either the fence post or big PVC hose and strap it to the bumper. Has anyone slung it under the trailer by the sewer outlet, and if so how did you do it..??????
steelpony5555 is offline   Reply With Quote
Old 10-04-2015, 06:42 PM   #2
Batts-toy's Avatar
There are many examples in this forum on your question, use the search function I am sure you will find what your looking for. Pictures included.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 10-04-2015, 06:49 PM   #3
Canadian Member
itat's Avatar
As Batts-toy said, if you search the forum you'll find lots of pictures of what folks have done to mount something under their trailer. If you're going to do this, consider mounting it far enough forward that it won't drag if you have to have the trailer put on a flatbed.
I have lots of room in the bed of my pickup so I just use a large Rubbermaid tote. It fits 2 Rhino sewer hoses plus the accessories and a green water hose that's dedicated for flushing the black tank.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 10-04-2015, 06:50 PM   #4
WolfWhistle's Avatar
Here's one from a XLR guy. It is a carrier kit from Lowes or HD.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 10-04-2015, 07:12 PM   #5
See post #11 here for what I did. The pdf has a couple minor errors in it, but you'll get the idea.
The pic is when it was on my Roo. It's now on my Mini-Lite.
How do YOO, like your ROO ?
2011 Traverse LT, 3.6L, FWD
Old 10-04-2015, 08:13 PM   #6
dieselguy's Avatar
This carries my outside rug, but could easily carry your hose. I had a couple of aluminum bands rolled and got a couple of blocks of aluminum for frame mounts. I used 6" PVC
dieselguy is offline   Reply With Quote
Old 10-04-2015, 08:23 PM   #7
Who Dares, Wins
doc73's Avatar
Here's my little setup
http://www.forestriverforums.com/for...d.php?p=932466
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 10-04-2015, 09:14 PM   #8
Left Coast
Like the quick pins!
Old 10-04-2015, 09:18 PM   #9
Yes, I did try the search function and tried various wording and never found anything. I figured there had to be something on here bout it. Guess what I really needed to know is what folks are using for brackets to attach the fence post or PVC to the trailer and what they attached to..... Guess what I need to do is go to Lowe's for an afternoon and nose around and see what I can adapt. Doc73 had some good ideas too, like the spring setup...
Old 10-04-2015, 09:30 PM   #10
Left Coast
Brackets can be formed from 1" wide flat-bar, thin stuff. just depends on what you use for the tube...round pvc ic heavy compared to the fence post cover. Use self-tapping 1/4 bolts with hex-heads and screw into frame ....pre-drill the frame a little smaller that the bolt size you select. Posts, if they have 'em will be in the garden center area and pvc will be in the plumb'n section
storage
