Old 09-29-2012, 04:40 PM   #1
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
Back-up light circuit pn 2013 Cedar Creek
Does anyone know if the 2013 Cedar Creek has a circuit for backup lights. I'm installing Magellan's addon backup camera and it needs the backup light circuit for installation. Don't relish the job that entails running a wire the full length in a new 5th wheel.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 10-03-2012, 04:04 PM   #2
The tail lights on the trailer should have backup lights in them.
2004 Ford F350 CC DRW Powerstroke
2013 CC Silverback 35QB4
B&W Companion Hitch
Prodigy Controller
dlturner00 is offline   Reply With Quote
Old 02-11-2013, 11:32 PM   #3
Campingnut's Avatar
Was there a reverse wire at the back or did you run a new one?
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 02-12-2013, 10:00 AM   #4
I am guessing that is a factory (couple of names and numbers floating around here) question.
On our 2013 we don't have backup lights. (seems crazy to me), but not sure about there actually being a line for it there.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 02-12-2013, 10:14 AM   #5
Dave_Monica's Avatar
I would seriously doubt that there's a back-up wire run to the camper tail lights. One way to check for sure would be by looking at the wiring from the campers 7 pin plug. The back-up light wire would be on the center terminal.
Dave
Old 02-13-2013, 06:17 AM   #6
Papi
Papicamper's Avatar
Why only backup?
Why not use any other source of 12 volts at the rear end? The camera won't be damaged by being "on" all the time (or at least during "lights on" time) and there would be a number of other ways to shut it off (the monitor portion). One possibility would be to power it from the marker lights. Just a bit inconvienent but if the alternative means running new power... Unless I'm missing something here. Interested in doing this myself so will watch for your success, etc.
PapiCamper
Cedar Creek 36CKTS
F350 Lariat ("Big Blue")
Papicamper is offline   Reply With Quote
Old 02-13-2013, 09:20 AM   #7
Campingnut's Avatar
I am actually looking for power at the back only when in reverse. So yes your idea is fine for a backup camera, it would be like having a rear view mirror when going down the road, it won't work for me.
Tim and Bev
2015 F-350
Old 02-17-2013, 11:02 PM   #8
Old Member
mikey's Avatar
When I get to the install, I found there is 1) no backup lights on the coach and 2) there is no wire for it either. Dang it! Had to run a separate wire (40 + ft BTW) them wire it into the 7 way connector.
Old 02-17-2013, 11:17 PM   #9
Campingnut's Avatar
How hard was it to get to the wiring for the trailer plug at the front of the trailer?
Tim and Bev
2015 F-350
Old 02-17-2013, 11:34 PM   #10
Old Member
mikey's Avatar
Besides standing on you noggin not hard at all. The 7 way has the wiring already, I just connected the new wire to it. Would have been a lot easier about 35 years ago though!
Travel safe & enjoy the ride!
Old 02-17-2013, 11:36 PM   #11
Campingnut's Avatar
Thanks. So were do you have to join the wire together at the front.
Tim and Bev
2015 F-350
