Old 06-26-2015, 12:41 PM   #1
Battery compartment
Does anyone have a modification for the battery compartment on a FR 38L Cedar Creek?
The batteries are stuck into this very compact area and to reach the batteries to service you have to take them out completely. It really sucks
craigi is offline   Reply With Quote
Old 06-26-2015, 06:42 PM   #2
Hutch333id's Avatar
I too would be interested in this. Getting the batteries out and then back in for the winter break was a PITA.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 06-26-2015, 07:16 PM   #3
I feel the pain my friend. I had them serviced on a road trip in TN and they really messed the TT up. They pulled some edging off from around the battery compartment and on top of that they let a small amount of battery acid on the outside of trailer. I don't want to get into that story. It was a trying to get some warranty work done. I bought 5er in Dallas and went to a place in TN. I was staying there for a couple of months so I thought I would get it done there in TN. NEVER AGAIN AT THIS PLACE......NEVER
Old 06-26-2015, 07:30 PM   #4
We have a 34 rlsa and also agree with everyone as far as the placement of the batteries! And I was dumb enough to add 2 more in the front basement!!! This and the placement of the tank for the lift system again make me wonder if the fellows that design these units ever use them!
Be interesting to see what others have maybe come up with!
LJ
Truck 2009 GMC 2500 HD,D/A,Ext.Cab,SB,air bags, lift kit, flow gate, etc.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
Camping Day's: 2012:25,2013:27,2014:38,2015:38
Little John is offline   Reply With Quote
Old 06-26-2015, 10:37 PM   #5
Hutch333id's Avatar
I cannot believe how inconvenient it is to get at the batteries. With the side hatch door open and the location of the battery box on the 38FL it leaves about 12" of space to access the battery compartment with no depth greater than the actual battery. Complete nightmare t get them in and out other than doing it by braille. You certainly can't see what you're doing. If it didn't get so cold here in the winter I'd be tempted to leave them in.
Richard & Diane
Old 06-26-2015, 10:54 PM   #6
I can't help with the compartment, but I 'can' tell you that it is perfectly fine to leave your batteries in place during winter. As long as you keep a decent charge on them there shouldn't be any concern about freezing.
I would physically disconnect, slap on a battery tender, or at least apply a charge every 30-60 days and call it good.
rana is offline   Reply With Quote
Old 06-26-2015, 11:38 PM   #7
Crockett's Avatar
x2...trojan site says they are good to 92 below if fully charged. also the discharge much more slowly in the cold as well.
Crockett is offline   Reply With Quote
Old 06-27-2015, 02:13 PM   #8
Not sure about the above statement from trojan as I know what happens to a battery in a car over the winter... Even though it's a pain in the back side I'll pull mine out...
Old 06-27-2015, 02:44 PM   #9
Like what? It's not uncommon in a car to have a severely depleted battery. Modern electronics plugged in here and there... only driving 10 minutes on a regular basis that doesn't allow the battery to fully recharge between uses and compounds the issue of a perpetually low battery scenario.
In that case, I can see where a car battery may have issues in extreme cold, but a fully charged disconnected RV battery isn't quite the same animal. Granted, an RV battery with a low charge isn't going to fair very well over winter in extreme cold, but it's also not going to fair much better in a warm garage where it will self discharge more rapidly.
Best case scenario.. fully charged, disconnected from any load, and the colder the better.
Old 06-27-2015, 06:58 PM   #10
CCRVOC
Ramblin Recks's Avatar
This is where I mounted four T-145s. Picture was taken just prior to my solar install so ignore the hap-hazard wiring...
Name:	bat box without cover.jpg
ID:	81346   Click image for larger version
ID:	81347   Click image for larger version
Name:	battery pylwood.jpg
ID:	81348   Click image for larger version
Name:	box without bats.jpg
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
battery
