Old 10-17-2014, 05:05 PM   #1
Battery disconnect
I have a 2015 Cedar Creek 36CKTS. For normal operations connected to shore power should the battery disconnect switch be in the on or off position?
Bill & Joy
Daisy & Roxie (our Poms)
2014 3500 Ram Laramie Mega Cab DRW Cummins 6.7L Diesel
bturner is offline   Reply With Quote
Old 10-17-2014, 05:14 PM   #2
raspivey's Avatar
Generally, on. Although there is some debate about whether or not it's good for the converter to supply 12V power for extended periods, I know from experience that it will do so. It normally won't, however, allow the converter to charge the battery when the disconnect is off.
Old 10-17-2014, 06:45 PM   #3
TURBS's Avatar
On.
In other words so converter charges batteries.
Turbs
Old 10-17-2014, 06:48 PM   #4
Terier's Avatar
Originally Posted by f1100turbo View Post
On.
Turbs
Thanks Turbs. For a moment I was wondering if I should be turning it off or not on my unit.
Old 10-18-2014, 07:37 AM   #5
Thanks. It's sort of confusing.
Bill & Joy
Old 10-18-2014, 11:39 AM   #6
raspivey's Avatar
I'll try to answer yes and no in the future.
Old 10-18-2014, 12:36 PM   #7
No not your answer the switch itself. The switch is labeled battery disconnect. It has two positions on and off. I assumed that battery disconnect on means the batteries are disconnected from the coach. Vice versa battery disconnect off means the batteries are connected to the coach...
Bill & Joy
Old 10-18-2014, 12:39 PM   #8
raspivey's Avatar
No, no...you're fine. I just took a string of replies the wrong way. I do that sometimes. As to on and off, probably makes more sense to say connected and disconnected.
Old 10-18-2014, 07:26 PM   #9
mycedarcreek's Avatar
I had mine in the on position and then i had to replace the converter so i leave it off except win we travel.
mycedarcreek is offline   Reply With Quote
Old 10-18-2014, 08:44 PM   #10
Jerry01's Avatar
When you are using the trailer, definitely keep it in the on position. Most things will not work in the off position. On my trailer, when in the off position, the only things that seem to work are the propane leak detector and the entry light when the screen door is opened. Not sure about the converter though. But the lights don't work, and I like to see at night. Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 10-19-2014, 11:13 AM   #11
Duckogram's Avatar
Hope you replaced your faulty converter with a good one that can be left on.
ILB ( | )
Old 10-19-2014, 11:22 AM   #12
Duckogram's Avatar
Just to make things model specific, your 36CKTS disconnect switch connects/disconnects the battery from the power distribution panel which powers your converter/battery charger. There is another power box in your front garage that powers your wireless remote, porch light, landing gear and brakes among a few other things. That fuse box is not switched. It's also the reason why your batteries will still drain if you don't disconnect them or use a solar/electric battery tender.
ILB ( | )
battery, battery disconnect
