Old 03-25-2015, 08:01 AM   #1
Battery disconnect question
Is this the right position for this switch hooked up to powerClick image for larger version
Name:	ImageUploadedByForest River Forums1427288460.848099.jpg
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 03-25-2015, 08:12 AM   #2
Former Full Timer
Duckogram's Avatar
Yes
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 03-25-2015, 10:40 AM   #3
bubbles's Avatar
DUCKOGRAM is probably right but this is another example of a misleading placard. Does it reference the disconnect or the battery? I would check for power inside, lights etc. (not hooked to shore power) for each position. Just a thought.
Old 03-25-2015, 07:39 PM   #4
I checked, I wanted to make sure and I was pretty sure someone on here could tell me.
Old 03-29-2015, 04:04 PM   #5
Mark and Becky's Avatar
Will the slides operate with the switch in the "off" position even if you have shore power hooked up?
Mark and Becky is offline   Reply With Quote
Old 03-29-2015, 04:14 PM   #6
Ford Idaho's Avatar
Yes.
Old 03-29-2015, 04:21 PM   #7
Hmmmm. Had my neighbors go over to open our trailer up today and the slides would not budge with the shore power on, but with the battery disconnect in the "off" position. Hope there is nothing else wrong.
Old 03-29-2015, 04:27 PM   #8
ColoradoRick's Avatar
Wow that is a misleading label....a big fail on the engineer who designed it! (My disconnect is just a little push/pull silver knob)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 03-29-2015, 04:29 PM   #9
Oakman's Avatar
There is nothing wrong with your Cedar Creek, the switch must be in the on position for the slides to operate. The slideouts require a strong 12 volt source to operate the slideouts, the converter alone doesn't provide enough 12 volt power.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-29-2015, 04:34 PM   #10
Ford Idaho's Avatar
Hummm, mine work just fine when hooked to 110/120v with the battery disconnected.
battery, battery disconnect
