Old 05-30-2019, 12:15 PM   #1
Battery hookup
I took a picture of battery hookup before taking batteries out last fall. Hooked it up this year I thought like the picture. I have 2 red(positive) and 2 black(negatives) and 2 18" red and black cables with rings on each end. I hooked red positives from trailer one to each battery and one black to each battery.. I hooked the 18" red cable to each positive. Left over is 18" black cable. Diagram on side of panel shows only 1 red cable to battery and jumper red cable to other battery. What is correct? I put in new batteries this year cause last years wouldn't charge up. Maybe dealer had it wrong? Took batteries out because previous used disconnect switch didn't shut all power off and had dead batteries in the spring.
Sorry for long post and thanks for any help. Don
Cedar Creek 2018 38FBD
todalake is offline   Reply With Quote
Old 05-30-2019, 12:24 PM   #2
Semperfi24's Avatar
Do you have (2) 12V batteries or (2) 6V batteries. It will make a difference in how you wire them up together.
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 05-30-2019, 01:08 PM   #3
2 Interstate 24DC 12 volt batteries. Always hooked to city power so these are backup.
Old 05-30-2019, 01:14 PM   #4
maybe this will help...
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 05-30-2019, 01:19 PM   #5
So both reds to postive + on battery 1 and both blacks to negative - on battery 2. And use jumpers to connect reds and blacks to corresponding terminals of 2 batteries. Would that be right? Parallel connections.
Old 05-30-2019, 01:23 PM   #6
Prime Member
What 5picker said.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
Forever in my memory and in my heart. Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 05-30-2019, 01:45 PM   #7
Yes but they also power your emergency trailer brakes.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 05-30-2019, 05:14 PM   #8
I have 2 red cables coming down from trailer and 2 black cables. Your diagram just shows 1 red and 1 black.
Old 05-30-2019, 05:16 PM   #9
Fulltime family RVer
Yes, that's fine.
Old 05-30-2019, 07:22 PM   #10
do you have an inverter for a residential refrigerator? it may have its own set of cables. and there may be even more as it is common for many devices to be wired directly to the batteries.
go back to that diagram that 5picker supplied. while it only shows single cables being connected to the batteries you want to connect any other cables you have to the same terminal as the single cables shown in the diagram. (i am excluding the jumpers). so all positive cables connect to the positive terminal of one battery and all negative cables connect to the negative terminal of the other battery. the jumpers connect the two positive terminals and the two negative terminals.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 05-30-2019, 07:32 PM   #11
I placed color electrical tape near the terminals on the surface of the batteries and wrapped the corresponding cable with the same color electrical tape.
No more confusion which cable goes where.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
battery
