Old 03-31-2012, 04:06 PM   #1
Battery not holding a charge
Anyone out there having issues with their batteries losing a charge even though the disconnect switch is off? I notice that the landing gear and slides will also work even though the battery switch is off, does this seem like a normal issue? the camper is four months old.
Pitcrew18 is offline   Reply With Quote
Old 03-31-2012, 04:36 PM   #2
H2oski
No this is not normal. Your battery is not disconnecting or the slide and landing gear wouldn't work. Without knowing which type of disconnect you have (cable type, Leaver type or rotary type) I can't give you much info. Your battery is staying connected that's why your batt is discarging. You will need to find where the disconnect located and the determine with a multi meter if it is accually disconnecting. If not figure out why. Sorry I couldn't be any more help.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 03-31-2012, 05:53 PM   #3
TURBS's Avatar
Slides and landing gear may be out out of the loop when battery is disconnected.
unhook your battery cables after a full charge and
See if it still goes dead before you go any further.
Old 03-31-2012, 06:50 PM   #4
Drinkin beer on the beach
Rod Johnson's Avatar
The battery shutoff in the trailer is convenient, but putting a disconnect right on the battery itself is probably the easiest and cheapest way to make sure the battery is really off.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 03-31-2012, 07:30 PM   #5
Just purchased a battery disconnect today, I have a feeling the one from the factory is not doing the job, hopefully this will take care of the issue. Thanks to all.
Old 04-08-2012, 12:46 PM   #6
textman's Avatar
Did you get this figured out? You've got me wanting to check mine now.
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 04-08-2012, 12:53 PM   #7
Oakman's Avatar
It always helps to put what trailer you own and what year it is in your signature. Not all units are built the same and many things vary from year to year. On my 2013 Silverback the factory installed battery disconnect cuts power to the inside of the trailer but not the landing gear. This is normal for my brand.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-08-2012, 01:46 PM   #8
Got mtn bike?
ddavis662's Avatar
On my Rockwood 2012 2904 SS.
If I do not disconnect the battery, it will discharge in a matter of days.
The only devise I see "on" is the gas sensor.
From what I can tell, nothing else is "running".
When the battery disconnect is "engaged", the power tongue jack and the slide out are the only 2 items that still will operate.
I take the fuse out of the power jack so no one can "play" with it.
ddavis662 is offline   Reply With Quote
battery
