Old 04-04-2019, 10:01 AM   #1
Bearings and seals spares
We own a 2018 Cedar Creek 34RE.
We would like to buy a set of bearings and oil seals.
How do I figure out sizes. 7 ton axle.
Wrote down the model number. Donít know where I put it.
Is it possible Cedar Creek might know?
tomkatb is offline   Reply With Quote
Old 04-04-2019, 11:18 AM   #2
racer4's Avatar
Get the axle number from the sticker on the axles.
Call Dexter with that number and they can look up the bearing numbers.
Or go to https://www.dexteraxle.com/ and look at the 600-8K Operation Maintenance Service Manual. Page 81 has a Bearing Replacement chart.
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension, Pace Edwards JackRabbit tonno, Transfer Flow aux fuel tank, B&W RVK3600 hitch
2017 Cedar Creek 36CKTS, Disc Brakes, 17.5"
racer4 is offline   Reply With Quote
Old 04-05-2019, 01:01 AM   #3
97flhtcui's Avatar
Outers bearing 14125A race 14276
Inner bearing 25580 race 25520
Dexter seal 01003600
Jack
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 04-05-2019, 02:45 PM   #4
Jim34RL's Avatar
Let all of us know when you use the Bearings if you do buy them! In my 4 years of ownership of my Cedar Creek 34RL I have only used grease seals when the WHEEL BEARINGS are re-packed.
I bet you that when you sell your camper the bearings will still be in the original packing and stored some where in the back of the garage!
Just saying!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 04-05-2019, 06:09 PM   #5
Just reflecting n a previous experience.
We were hauling a sailboat for a big race in lake Sinclair near Detroit.
One set of bearings shotb craps about 6 pm. We limped onto a nasty abandoned shopping center. Too late to do anything. So, we decided to sleep in the boat and figure out what to do. About 11 we got a knock on the hull.
A local cop asked us what the hell were we doing there!
We explained. He looked at us and said you are not in a good place.
Iíll pass by every half hour and get the next shift to do the same until you are outa here. Really good guy.
Since then I always carry spare bearings.
Mental likely. I will let you know when I use them. Sort of suspenders, a belt and a rope.
Old 04-06-2019, 01:11 PM   #6
Spares
For what little a new set of bearings cost I keep a set in the camper. I hand pack my bearings every year but you just never know. Cheap insurance.
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
Handydc is offline   Reply With Quote
Old 04-06-2019, 03:22 PM   #7
X2, but I take it a step further. I have never trusted repacking bearings. If a pitted bearing is missed on an inspection or dirt particle are left in the bearings, it could cause a failure. For the cost, I have just bought new bearings and seals, packed them and installed them. Just in case, I carry a spare set, grease to pack, and tools to change. Years ago, we had a bad experience with truck bearings right after getting it out of the shop.
PenJoe is offline   Reply With Quote
Old 04-06-2019, 03:55 PM   #8
Bluepill's Avatar
Just saying!
Just like fire insurance on a home, we always hope to never need them, but one experience made me a believer. 1972, towing a boat trailer from NY to FL, I ended up with a toasted bearing at 5AM on a Sunday in Fair Play, SC.
Let's just say that the whole tale makes a great 5 minute campfire story.
Old 04-06-2019, 08:01 PM   #9
Filterman's Avatar
Took a picture of the package of all bearings, seals, axle tags and backing plate numbers when I did my first service. Keep them all on my phone. Always carry a set of bearings and seals and tools just in case. We travel some pretty remote areas , that no one services .
Filterman is offline   Reply With Quote
Old 04-07-2019, 09:16 AM   #10
So if you guys have the ezlube axles why would you manually repack the bearings? I think Iím missing something. But thatís not unusual.
MikeRP is offline   Reply With Quote
Old 04-07-2019, 09:21 AM   #11
Can't inspect bearings if you never pull them . or replace seals , recommend pulling and hand pack at least every 10,000 miles you can use the ez-lube between packs if you do it right
MR.M is offline   Reply With Quote
Old 04-07-2019, 09:38 AM   #12
Old school. Trust what you can see. EZlube, too much grease, too little grease, dislodged seal, water/dirt intrusion, bearing rust/heat discoloration? Don't take chances.
bearings, seal
