Old 03-26-2014, 10:36 AM   #1
Bed room air
Has anybody had any problem when you clean your filter when you put it back on if the tabs on your break off never had a problem on the older units but the new ones are cheaper I cleaned my filter twice and the tab broke a replacement is $16.95 !
Cowboy52 is offline   Reply With Quote
Old 03-26-2014, 04:28 PM   #2
Former Full Timer
Duckogram's Avatar
The tab that the rubber band goes on or the tab that keeps the door up?
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 03-26-2014, 04:30 PM   #3
The tab that keeps it up !
Old 03-26-2014, 06:35 PM   #4
Former Full Timer
Duckogram's Avatar
Keeping Tabs
The plastic on some brands is a bit thin these days. I would not keep buying the same poor quality product especially at $17. a copy.
You can easily install nylon screen door retaining clips in white
which would be fully functional, hardly noticeable and much more economical.
Those spring plastic clips become brittle over time and are sensitive to cold.
Just a thought.
Old 03-28-2014, 06:50 AM   #5
I've not had a problem, yet, but they are pretty flimsy. However, I agree with Ducky. When they break, I'll modify it somehow.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
bed, roo
