Old 07-17-2015, 11:14 PM   #1
richard75w's Avatar
Bedroom Closet Is HOT!
I have a 2014 Silverback 37BH, which I use 100% for work. (Petroleum Landman) Anyway, I spend at least four nights a week in it, almost year round as my work keeps me on the road.
My bedroom closet, like many models, is located directly behind the front cap of my fifth wheel. We have had a mild summer so far (for Texas) and it's only recently gotten near the 100 degree mark. I have noticed this every summer, but didn't think to get input from this forum. It seems that there is no insulation up front.
Does anyone have the same problem, and if so, how can I mitigate it?
Thanks!
richard75w is offline   Reply With Quote
Old 07-18-2015, 06:40 AM   #2
You might consider added insulation from Home Depot that could be seasonally velcro'd inside the highest areas of the cap getting the sun OR some reflective weather proof heat shield on the outside upper front portion to deflect heat ( not going to be pretty ) OR BOTH.
Keep closet doors open and buy 2 small high velocity fans, one for each side to keep air circulating.
SilverbackMel is offline   Reply With Quote
Old 07-18-2015, 06:50 AM   #3
davel1971's Avatar
common problem I'm sure. My Coachmen 5th wheel has a dark brown cap, so it's pretty bad. I'm going to install the 2nd ac in the bedroom since it makes the bedroom hard to cool. Might just have to leave closet door open, at least when the sun is shining on the cap.
David & Lynn
Old 07-18-2015, 07:07 AM   #4
clr
It gets hot in the summer or cold in the winter because there is no air flow in the closet with the doors closed. There is no heating or cooling vents in a closet. So if you want your cloths to be more comfortable just leave the door open some.
clr is offline   Reply With Quote
Old 07-18-2015, 07:49 AM   #5
Have that
2nd air runs 24 x 7 in this heat. Closet
still has DEAD AIR. Need a fan or 2 even w ac. And BTW, my 2011 Keystone had a light cap and front bunkhouse and it was hot in summer, cold in winter. Brown may draw heat but really it's all about the BUILD.
Leaving the closet open does help, BUT, if packed with clothes, no breathing room for air flow.
Another tip: even w 2 ac's ( for the oil worker ) when family is not there, I CLOSE bedroom slide and one LR slide when gone for the day. It reduces heat exposure and cools better. I set stuff so nothing to move; just push the buttons. Lv my heavy kitchen slide out.
Old 07-18-2015, 07:58 AM   #6
Georgia Frog Rally 2018
aceinspp's Avatar
Having 3 slides and only one AC for those temps will also make it hard for the AC to keep cool. As you found out closing sofme during the day helps. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-18-2015, 08:16 AM   #7
Clairification: SilverbackMel has dual AC. It's still HOT IN DA CLOSET.... Moral of the story:
Come out of the closet ��
Old 07-18-2015, 08:21 AM   #8
aceinspp's Avatar
Yep I got the 3 slides and 2 AC and yep still will get warm on very hot days. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 07-18-2015, 08:48 AM   #9
Witch Doctor's Avatar
Thanks!
Every cap I have seen taken off only has cross members no insulation that I have seen yet. You might want to go to lowes or HD and pick up some of that silver insulation and put it against the back wall inside the closet, that might help. I think it's rated at R-9. Would be easy to cut and use spay glue by 3M to hold it up.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 07-18-2015, 12:35 PM   #10
rugersdad's Avatar
Our Cardinal was hot also. Removed the upper panel in the closet and stuffed a 50 foot roll of fiberglass insulation in the un insulated cap, a large handful at a time, problem solved. Ventilating the closet is not necessary.
rugersdad is offline   Reply With Quote
bed, roo
