Old 07-11-2019, 08:46 AM   #1
Bedroom floor
We have a 2017 Silverback 29RE when I open the slides most of the time I find water on the bottom of the outside edge of the bedroom slide floor by the screws that attach aluminum angle to the floor. I cannot figure out where it is coming from . I have resealed the joint on the outside of the slide. Has anyone else had this problem. Thanks for your help
jjcook is offline   Reply With Quote
Old 07-13-2019, 02:45 PM   #2
A picture of the outside Aluminum angle would be helpful. We had a 2010 Wildcat that had same issue. The aluminum extended past the edge of the slide and was not sealed along the top edge and where it met the outside edge of the slide water would get behind the angle and would drop on the floor when it was extended.
Removed the aluminum, sealed it properly and cut about 2 inches off the end. This probably was not necessary after it was sealed, but never had that leak again.
Rich5117 is offline   Reply With Quote
bed, floor, roo
