Old 08-20-2014, 07:41 AM   #21
Mine was $324.00 for the 507 with pass through, 6 sensors and free shipping plus 3 year warranty.
Kevin & Judy is offline   Reply With Quote
Old 08-20-2014, 09:02 AM   #22
TxTravelingRN's Avatar
Where did you find that price? On TST website 507 flow-through base unit with 4 sensors is $259 and 2 yr warranty. Additional 1 yr warranty is $50, 2 additional sensors $100. Total $409.
2013 F350 Lariat 6.7 Diesel DRW
2013 Rockwood Ultralite 2608 WS
2013 Days Camping: 61
2014 Days Camping: 200+
TxTravelingRN is offline   Reply With Quote
Old 08-20-2014, 09:20 AM   #23
Originally Posted by f1100turbo View Post
Tire traker with 8 sensors is $340.00
3 year warranty.
TURBS
"SABRE OWNERS UNITED"
Really considering this system as it has a better price. ALL of these systems are made by the same China manufacturer. The only difference in them is the packaging and price.
The only drawback I see is they don't offer a flow-through sensor that I desperately want for inner tires on dually. Those tires are very difficult to access and was going to use flow-through as a pseudo valve stem extender. The alternative would be to have tires remounted with a longer curved stem that is accessible. The less expensive price though would probably pay for the remounting. I just don't want to use an extender + sensor as it creates too many areas for air leakage. I'm already planning on having these cheap Chinese tires on TT replaced with better grade and metal curved stems.
What a money pit! lol I've learned a valuable lesson though. I'll add metal valve stems to my PDI list for my next purchase. Can't believe FR, dealership would put on cheap tires AND rubber valve stems... a disaster waiting to happen.
Old 08-20-2014, 09:27 AM   #24
TURBS's Avatar
You can get extended length metal valve stems for you dually so you don't have to use extenders.
I just sent old coot some metal valve stems for his trailer!
TURBS
Old 08-20-2014, 09:42 AM   #25
Originally Posted by spock123 View Post
You should try Great RV Products and I think you can get a better price on the TST 507. 8 sensors for 399 plus 3 year warranty no tax and free shipping. 4 sensors for 239
Thanks for the suggestion.
Just checked out Great RV Products . Great prices for the system. Better than Camping World and not as limited in choices. Camping World only seems to offer the outdated 510 and the 507 Flow-Through. I don't have any need for either as 510 is not practical (non-replaceable batteries) and can't use 507 Flow-Through.
What I need: TST 507 + 507 Flow Through Additional Sensors (2) - Great RV Products . Total: 399 + 100=$499
Old 08-20-2014, 10:00 AM   #26
Purchased it direct from TST..
Old 08-20-2014, 10:04 AM   #27
TURBS
Probably the best long-term plan to go with extended metal valve stems rather than extenders. Thanks for the suggestion.
TireTracker 10 sensor price: $429 + remounting of inner dually (~$50)=$479.
https://www.tiretraker.com/proddetai...prod=TT400C-10 .
Comparison of TST 507 via Great RV Products and TireTraker essentially the same cost. $479 vs $499.
Old 08-20-2014, 10:37 AM   #28
dcheatwood's Avatar
Thanks turbs. Yes, I was out in one of the rains putting mine on. (Only time my wife would sit still inside.) No trouble so far. Had one stop sending on the way home and monitored notified me. I took battery out, cleaned it, and reinstalled. Back up and running. Only complaint is the time delay for first reading.
Forgot about registering. Will do that now. Thanks again.
2018 Forester 3011 DS
Old 08-20-2014, 10:59 AM   #29
dcheatwood's Avatar
Don't know how they do this, I've never bought from them but this price for trailer TST looks pretty good. I was going to order these until I saw Tire Traker at the Goshen Rally.
TST 507RV 4 Wheel Trailer System w/ Flow-Through Sensors for Sale Online - Vulcan Tire Sales
Old 08-20-2014, 11:09 AM   #30
BoatDude's Avatar
Hello RN......I took my F350 dually to tire barn and they rotated the outside rear tires (stem) about 180 from the inside tire. The inside tire stem is not exactly centered to the outside rim hole but very close. It allowed me to easily install the EEZtire T515 sensors to both dually wheels. If access to the stems ever become an issue. ....I will have new longer valve stem installed to replace the originals. But I like the install.....it worked out.
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 08-20-2014, 11:11 AM   #31
$ 499 for the 507RV 10 sensors.
$ 737 for PressurePro 10. Ouch!
Old 08-20-2014, 12:32 PM   #32
At a Ford dealership in SD right now to get coolant pH checked. Talked to their tire guy...wasn't familiar with a long valve stem, only extensions. Think I'll check with a tire store as they are more familiar with after market supplies. The saga continues...this is much more difficult than it should be. I would think this is a common issue that has been addressed by Ford and others.
Old 08-20-2014, 12:41 PM   #33
TURBS's Avatar
Lol I just had a DUH moment.
Is you truck new enough to already have factory installed tpms?
If so that may be an issue.
1) they'll have to remove all the truck tpms sensors , problem is your tpms light will be on then.
I know they can shut it off but "will they"?
TURBS
Old 08-20-2014, 12:46 PM   #34
TURBS
2013 Ford Dually isn't available with factory installed TPMS, only the SRW is. I'd remove it if it was there as I've heard there are issues with it.
Old 08-20-2014, 01:22 PM   #35
TURBS's Avatar
Your set then.
Fyi there's PLENTY of options.
ID:	61014Click image for larger version
TURBS
Old 08-20-2014, 01:59 PM   #36
Your set then.
TURBS
Looking to find some Borg dually valve stems. They seem to be recommended on a lot of RV sites. Thanks
Didn't mean to hijack thread! Sorry OP.
Old 08-20-2014, 05:58 PM   #37
I don't know about Dodge and Ford but Silverado 1 ton trucks do not come with TPMS. A 3/4 ton does. When I first got my 12 silverado I looked for a day or two until I found out the TPMS was not on 1 ton pickups
spock123 is offline   Reply With Quote
pressure, tire
