Old 07-30-2013, 09:28 AM   #1
ret2006's Avatar
Better check those A/C and heat vents
After two months since I picked up our new 2014 Cedar Creek 34 RLSA I got around to cleaning out the A/C and heat ducts and vents. I was very pleased with the heat vents and ducts, not much saw dust and the duct work was sealed well with aluminium HVAC tape. I was not pleased when I got to the ceiling A/C outlets. Out of 7 outlets, none were sealed around the edges and most had a 1/4 " gap in places. Then I found one where they entirely missed the opening in the ceiling by about 2 inches (picture attached). I sealed all the edges and gaps with HVAC aluminum tape. All the gaps were pushing cool air between the roof and ceiling. I am guessing I may have increased my cooling efficiency by 10 to 15%, maybe more.
Better check yours.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 08-05-2013, 08:10 PM   #2
Thanks for the heads up. I checked our vents and although I didn't see any out of alignment as you found, I did see plenty of gap for air to leak into the attic through. I will foil taping around the seam to stop the extra attic cooling. Even Duct tape would do the trick.
2012 GMC 3500 Duramax Crew Cab, SuperGlide 20k
2014 Cedar Creek 36B4, LP Onan, Level-Up, Trail-Air pin, electric fridge
Campwell is offline   Reply With Quote
Old 08-11-2013, 07:48 AM   #3
Cowboy 54's Avatar
Do the covers just pop off
Cowboy 54 is offline   Reply With Quote
Old 08-11-2013, 08:00 AM   #4
Yes. I just pulled mine downward.
Old 08-11-2013, 08:08 AM   #5
Cowboy 54's Avatar
Thanks I'm going to check mine the return air they have between 1/4 to 1/2 inch gap will fix that !
vent
