Old 10-13-2016, 11:24 AM   #1
mbbutler's Avatar
Beware of Plumbing
I have had 3 significant plumbing leaks since buying my 33IK in April. In each case the plumbing joint should have had teflon tape or pipe joint compound. Not a single one did. Thank you for the great QC FR. These types of shortcuts aren't easily forgiven due to the effort to correct after the purchase.
2008 F250 6.4l srw
2016 CC SB 33ik
Georgia Based
mbbutler is offline   Reply With Quote
Old 10-13-2016, 01:53 PM   #2
dieselguy's Avatar
It generally not advised to put pipe joint compound on plastic fittings, but I know what you mean about leaks on new units.
dieselguy is offline   Reply With Quote
Old 10-13-2016, 02:19 PM   #3
DDC
DDC's Avatar
Can I ask where they were I got my 33IK in May and it would be nice to check and see if it was the same irresponsible employee putting mine together.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is online now   Reply With Quote
Old 10-13-2016, 06:31 PM   #4
keith52's Avatar
Not defending or pointing the finger at any of the rv manufacturers. But, I'll bet money that if you look at any new rv, none will have teflon tape or joint compound. The new plastic fittings are either glued or compression fittings. I know my previous rv had bare fittings and I had to re-tighten a few several times. Just part of the rv adventure.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
keith52 is online now   Reply With Quote
Old 10-13-2016, 10:09 PM   #5
sgtlm17's Avatar
Plastic fittings typically do not require Teflon tape or compound. That said i use it anyway when doing a repair.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 10-17-2016, 01:15 PM   #6
mbbutler's Avatar
These were not plastic fitting:
1) kitchen faucet where sprayer hose attached to faucet, not sprayer end.
2) bathroom lavatory feed. Brass pek connector to cold water side.
3) hot water output from water heater.
I realize #1 was a FR supplier and not FR staff. Assuming kitchen sink comes preassembled.
2008 F250 6.4l srw
2016 CC SB 33ik
Georgia Based
Old 10-17-2016, 02:26 PM   #7
DDC
DDC's Avatar
Thanks I can check mine now with extra attention to these ones.
plumbing
