Old 07-31-2016, 06:56 PM   #11
Originally Posted by dalford View Post
That's what I said.. Glad we agree...
Just going by your post. "
Quote: Originally Posted by dalford View Post
I had the same issue when flushing the tank. I just posted this post last week on how I eliminated my problem. Really bad odor when flushing the tank. When flushing the tank air is displaced by the water and goes out the stack vent...
Sorry to disagree, when water exits the black tank, air is DRAWN in thru the roof vent, not out. When you flush the stool, the water/debris goes into the tank and PUSHES air out the roof vent."
Old 07-31-2016, 07:25 PM   #12
I guess you feel argument today, so be it... I quests you can also ignore my post #8 where I clarified how I flush the tank ...
Please Depends on what "flush the tank' means. Maybe I should have been more specific.. When I back flush my tank I usually drain the black tank with black valve open. I then close the black tank valve while still flushing, thus putting water in the closed tank. Smell has to go out the stack being displaced by water."
So be it...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 07-31-2016, 07:33 PM   #13
asquared's Avatar
Moving on, back to the OP's issue. Are you keeping water in your black tank at all times? As stated above, make sure the bathroom fan is off, water in toilet bowl and lid closed.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
