Old 06-05-2019, 09:29 AM   #1
Bike rack
I HAVE A CC CHAMPANGE 38EL 2019,I have been researching bike racks and not too many manufactures make bike racks for a fifth wheel with a 1 1/4 receiver .IF they do make them they are for a 2 inch hitch. ANY SUGGESTIONS.IM specifically looking for 5th wheel comparable.
BOB3288 is offline   Reply With Quote
Old 06-05-2019, 09:56 AM   #2
Not sure what you mean by "5th wheel comparable." You can put pretty much any bike rack on anything that has a receiver.
If what you mean is a rack "approved for RV use," Swagman makes several. Go to etrailer and look around.
I'm not sure what "approved for RV use" really means. I've been using a Thule TH990XT for about 10 years, on both my Roo 19 and my Mini Lite 2503S (as well as my truck). It's NOT "RV approved," but it works just fine. It fits 1-1/4" receivers, but has an adapter to fit 2" receivers. (I've had beefed up recievers welded to both TT's.)
On my Roo:
On my Mini Lite:
Name:	Mini Lite at Wolf River CG 1 Aug 2016.jpg
2011 Traverse LT, 3.6L, FWD
Old 06-05-2019, 11:35 AM   #3
I'm interested in this as well. I used an adapter to use my 2 inch Thule 2 bike rack on the back of my 36CK. Watched with my back up camera to see them bouncing around due to the inadequate support of the 1.25 inch receiver on the camper. By the time I stopped, two of the rubber straps were missing from my rack and bikes were ready to fall off. For now I will stick with the 2 inch receiver I installed on the front of my F350.
stesmi52 is offline   Reply With Quote
Old 06-05-2019, 03:42 PM   #4
Does your Thule utilize a pinch bolt as a hitch pin? Mine does, so no (very little) bouncing around.
The rack has a nut inside the racks drawbar that you screw the bolt into, then tighten with a wrench. You can put a lock on the opposite end. (It's also important to keep all the rest of the bolts on the rack tight, too, or you'll see some bouncing around.)
You can get the pin at etrailer:
https://www.etrailer.com/Accessories.../853-5917.html
Old 06-05-2019, 03:56 PM   #5
Jim34RL's Avatar
Will I do carry bikes sometimes on my Cedar Creek, I do not have any hitch on the trailer. I carry a Trek (mine) and my wife's Schwinn on the rear ladder. Works great with the bike rack which is a, Surco Bike Rack model no. 501BR. Here is a link to Amazon that carries this rack. https://www.amazon.com/Surco-501BR-L.../dp/B001GXO0F6
Just another suggest for carrying bikes.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 06-05-2019, 04:11 PM   #6
I bought a set of these...
https://store.lci1.com/storage-rack-...ed-373965.html
intending then to use it with this...
https://store.lci1.com/flip-down-slo...em-243621.html
The pivot hardware attaches to the frame, not the bumper. Unfortunately there is not enough clearance on my silverback to put it on in the way it is intended. I finally put it on backwards, which will allow me to put a rack on, but not flip it up.
I've fabricated a frame to hold bikes out of 2x2 aluminum framing. When I get it finished I'll post photos.
I had purchased a 1 1/4 " receiver bike rack that I was going to put on the factory hitch receiver, but it moved more than I liked.
Jim
2018 Chevy 3500 Crew Cab, 4WD Duramax
2019 Cedar Creek Silverback 33ik
Jim in Florida is offline   Reply With Quote
Old 06-05-2019, 04:17 PM   #7
Yes it does, so no help.
Old 06-05-2019, 04:19 PM   #8
Tried this also, on my Bighorn. The ladder standoffs broke and dragged my bikes. Won't do that again!
Old 06-05-2019, 04:24 PM   #9
My problem is more likely the lousy roads that we have to travel in the northeast. The 1.25 inch receiver just has too much flexibility to hold the rack securely in the rough conditions.
Old 06-05-2019, 04:44 PM   #10
bikendan's Avatar
I would NEVER use a 1 1/4 bike rack, on the back of any RV. Especially a towable.
Equalizer WDH
Old 06-05-2019, 06:58 PM   #11
Jim34RL's Avatar
How many and how heavy were the bikes?
Something was terrible wrong with your ladder if the stand off's broke by carrying bikes! I know my bikes weigh less than my body weight and I go up and down my ladder all of the time!. Bikes weigh around 40LBs combined.
Another thing the down ward force of two bikes mounted on the ladder and secured to the ladder would not cause the ladder stand off's to fail!
Jim W.
Old 06-05-2019, 07:47 PM   #12
2 bikes, same weight. Have seen and heard of several similar failures.
Old 06-05-2019, 10:02 PM   #13
SilhouettePenny's Avatar
Ladder bike hangers, bumper bike racks and 1-1/4" hitches are accidents waiting to happen...bouncing around behind a camper, TT or 5er. So I'm fabricating a hitch point with dual 2" receivers for the 5th wheel. In-progress hitch mod in photo. 9/16 grade 8 hardware for attaching to frame. Bike platform design to come...
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 06-06-2019, 08:32 AM   #14
Jim34RL's Avatar
Did you calculate the shear load on a 9/16 bolt? Grade 8 hardware does not really help you on shear strength, it really only works on tensile strength. You need to calculate the cross sectional area of the minor diameter area of the 9/16 bolt. When you do shear strength which is smaller then the 9/16 diameter of the bolt. I would prefer 5/8 or larger diameter for a shear strength on a bolt.
Jim W.
Old 06-07-2019, 10:07 AM   #15
Good point sir, perhaps reconsideration is in order. Per your recommendation I've upgraded the bolt diameter, now to find a drill bit large enough for the task.
2019.5 Hathaway
Old 06-09-2019, 06:20 AM   #16
CCSILVERBACKBJANDA's Avatar
I replaced the 1 1/4 receiver hitch with a Class III 2 receiver hitch. Use a swagman 2 bike rack with no issues! 2014 Silverback 29RE
I would not trust the original hitch with anything. Class III hitch purchased on etrailer. Adjustable for any size camper.
CCSILVERBACKBJANDA is offline   Reply With Quote
Old 06-09-2019, 06:23 AM   #17
https://www.etrailer.com/dept-pg-RV_...per_Hitch.aspx
Old 06-10-2019, 05:43 PM   #18
When we ordered our 2018 36CK2, we tried to specify that we wanted a 2" receiver hitch, but came with a 1 1/4 receiver instead.
CC indicated something about if they were to put a 2" receiver on, owners would start towing something cars, boats, etc. which they wouldn't warranty the frame then.
I contacted Swagman about the 1 1/4 platform carrier I had before we bought, which has an orange tag right on it, stating 'Not for use on back of Travel Trailer or Motorhome'. They said the whipping up and down would cause the carrier to fail. They recommended a 2" platform carrier version.
CC said that is why they put the 1 1/4" is to make sure it is used only for carrying bikes but never offered a platform bike carrier that would be able to use. Ends up my 1 1/4" receiver is useless as have never used it. Wish they would provide the option of one that would work ok in a 1 1/4".
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2015 Chevy 2500HD Crew Cab 4X4 SRW Duramax
Demco AutoSlide 18k
GMRCK25D - Rear Axle Timbren SES Suspension Upgrade
LittleBill is offline   Reply With Quote
Old 06-10-2019, 05:45 PM   #19
Meant to mention I may at some point replace the 1 1/4" with a 2" receiver so can take our bikes.
Demco AutoSlide 18k
Old 06-10-2019, 07:04 PM   #20
Jim
Checked the fit today and am pretty happy with it. The ends slide into the pivot hardware which are mounted to the frame. Two 3/4" bolts at each end keep it in the pivot mount.
I may also use a center support for the outboard frame using the 1 1/4" receiver.
I still have to knock any sharp corners off and paint.
Jim
ID:	206968   Click image for larger version
ID:	206969   Click image for larger version
bike, bike rack
