04-25-2019, 09:36 PM
Binds/Shades Up or Down while traveling?
Hey the DW raised a question about whether the blinds should be up or down while traveling in our 2018 36CK2. While we generally always have traveled with them down, we found today that one of the bottom hold-down brackets for the curtain on one of the windows was broken. Thought is that the binds swinging back and forth while traveling over our illustrious roads probably may have broken it. Your thoughts on whether up or down. I tend to lean down but that may not be right. Thanks
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
04-25-2019, 09:46 PM
We've done both without problems, but I guess if you're on the right road, it could shake it up a bit. I'd say we normally have the shades down when traveling.
04-25-2019, 10:39 PM
Down helps keep coach cooler.
2016 F350 PSD SRW 4x4
2019 325 Wolfpack 13
04-25-2019, 11:35 PM
On our tt, we put the shades up. It may depend on the type of shades you have. Ours had no way to tie the ends to the trailer when down... so the shades would flap around while traveling. We figured that keeping them up would minimize damage.
2015 Dynamax REV 24TB class C
04-26-2019, 03:40 AM
I have done it both ways, now in the down position, when up they swing a lot more.
Coachmen M/H
Concord
2018 / 300 DSC
04-26-2019, 05:06 AM
"On the road again"
Ours are generally down while traveling (keeping the coach cooler) - but we have inadvertently left some of them up a time or two with absolutely no issue. We've been on those terrible roads around Shreveport where it feels like you're on a wash-board. Even that catastrophe section of I-20 didn't damage our shades.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
04-26-2019, 05:39 AM
We keep ours down, helps keep pirates from scoping out what in there when parked along the way.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
04-26-2019, 04:21 PM
We travel with our shades up in our 33IK. Don’t need them swing around as we travel the roads. Windows are tinted so you can t see in.
04-26-2019, 05:17 PM
x2 - up when traveling.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
04-26-2019, 05:39 PM
Drew
In the MH we travel with them up, otherwise they flap around and make a lot of noise.
04-26-2019, 06:45 PM
Up so they don’t swing all over the place.
04-26-2019, 08:20 PM
Global Nomad
I have a 2016 36CKTS Cedar Creek. For the first 2 years of our full time travel I kept the shades up. However, the brackets holding the shades broke on 3 shades during that period. Cedar Creek replaced those brackets, but now I keep them down (the lower curtain clips prevent the shades from flapping around), no broken brackets since keeping them down.
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
04-26-2019, 08:30 PM
shades
Shades up for us.
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
04-28-2019, 07:31 AM
Window Blinds
We travel with our blinds up. I feel there is less strain, on the brackets holding them up, having all the weight of the blind bouncing upend down on the tube brackets. Our windows are tinted, no can see in.
04-28-2019, 07:41 AM
I've never given it a thought, and still won't
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
04-28-2019, 07:46 AM
I suppose it depends on the type shade you have. Ours are more secure down than up.
We had a SOB that was opposite and if left down, would break the clips.
There is no "one answer fits all" to this question.
04-28-2019, 10:45 PM
We keep all shades down while travelling to keep out the sun, keep the trailer cool, and keep out prying eyes when we park. Our Cardinal has ten windows with lots of tempting, expensive hardware inside.
