Old 02-24-2016, 12:46 PM   #21
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I agree with Sheldon211,,,,WD40 also gums up after a while. I foung out years ago that it's nails in the coffin if you squirt it into a keylock mechanism. Silicon or waterproof grease is good.
Grampa Jim is offline   Reply With Quote
Old 02-29-2016, 06:24 AM   #22
Black Valve
Originally Posted by TimfmCt View Post
Good morning,
Thank goodness for this forum. The black tank dump handle is VERY hard to pull out and push back in. Does the shaft run through a long casing to the actual gate? If so can it be lubricated?
Tim fm Ct
Mine was stuck in the open position. Cable was the problem. The cable was a stranded wire which had swollen on the upper end so that it would not recede into the cable housing thus valve would not close. Replaced the cable works again.
It is still hard to open and close all of mine are. we I had the valve removed it was smooth and easy to operate when installed hard.
I replaced the stranded wire cable with a solid cable.
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
black, black tank, tank
