Old 02-07-2016, 10:57 PM   #11
All, (Unless it is from a well with just it attached) so called "Non Potable" water at campground dump stations (or other dump stations for that matter,) comes from the potable water supply ... After it passes thru a Backflow Preventer . IMHO it is labeled as Non Potable due to your not knowing if the last to use it stuffed the hose into his black tank and contaminated the hose, hose Bibb, etc. As I have been plumbing for over 30 years it has been drilled into me that we plumbers protect the health of the nation and so removing a backflow assembly that is in place to protect you and your family is not the smartest thing to do, unless you place it somewhere else. The Air gap fitting that is used in the black flush line is a very cheap plastic fitting that should be replaced with a better assembly or relocated to where it can not do damage WHEN it leaks. Our new TT is the first to have this option and our air gap is under the kitchen sink. My plan is to remove it and add a 1/2" RPBA that I can hookup outside the trailer to flush the tank.
Much safer assembly than the existing air gap assembly health and leak wise.
Happy Camping
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is online now   Reply With Quote
Old 02-08-2016, 12:13 PM   #12
Canadian Member
itat's Avatar
Dwilcox, I agree. I've been a specifier in the municipal water supply industry for over 20 years. The worst disaster we've seen up here in Canada was in Walkerton, Ontario where 7 people died and 2500 got ill from E. coli contamination at a well head. We're not talking about that extreme on this thread but just the thought of someone being careless and contaminating a water supply gives me shivers.
I'm looking at getting a Watts No. 7 dual check valve for my setup so it can be on the outside rather than hiding behind a panel. I'm not a plumber, but I think this should do the trick. What do you think?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 02-08-2016, 12:32 PM   #13
Angry
irish01, I don't know about your rig but on our 2015 Columbus 320RS the line goes up through the storage compartment floor BEHIND the shower! To access it requires removing the water controls panel on shower wall and reaching in and to the right. It is attached with a plastic strap to a wood stud. What a pain!
baysalr is offline   Reply With Quote
Old 02-08-2016, 01:37 PM   #14
Left Coast
That's the one.....I installed mine permanent just inside the outside wall, and did away with all the extra hose
Old 02-08-2016, 11:26 PM   #15
Itat, the duel check should do the job, our health department would want a RP if they knew what was going on. I have heard thru the grape vine that the purveyors down here are looking at requiring RP'S on camp grounds because of the black tanks, and how they can't control how a camper flushes them with the potable water at the site. We see minor contamination all the time, unfortunately you need a body count for folks to sit up and take notice. Our job is to do what we can to keep,that from happening.
Dale & Karen
Old 02-09-2016, 05:15 AM   #16
Stevemc's Avatar
So forgive me for my ignorance but we never had a problem with our check valve in our previous trailer so didn't have a reason to learn about it. The check valve just needs to be between the water source and the trailer and thus can be installed internally or externally? So it only protects the water source but the internal rv plumbing can get contaminated?
Steve & Jean
Furbaby - T.J.
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 02-09-2016, 06:22 AM   #17
They, back flow/check valve are installed to Protect the Incoming Water Supply from being Breached! This Black Tank Rinse System in your RV will NOT Contaminate your RV Fresh Water System! Youroo!! This is for Post # 16!
Old 02-09-2016, 09:06 AM   #18
They are 2 separate systems. You would have to use your potable hose, contaminate it, then hook it up to your city water inlet. That is why you want to have a hose for black flush only. That includes rinsing the drain hose.
Dale & Karen
Old 02-09-2016, 09:08 AM   #19
Stevemc's Avatar
Sorry I misunderstood. I see now we are talking about the black tank flush system. I was reading where this valve is located under the bathroom sink or sometimes the kitchen sink and jumped to the conclusion that it was in the rv water plumbing system.
Is there also a similar check valve in the system that keeps water from filling the freshwater tank when hooked up to city water?
Steve & Jean
Furbaby - T.J.
Old 02-09-2016, 09:10 AM   #20
Left Coast
Yes. In water pump
black, black tank, black tank flush, tank
