Old 02-07-2016, 04:10 PM   #1
Black tank flush Check Valve
Anyone know where I can find this. Blue water line goes through Bathroom floor above cargo bay and back to top of Black Tank. Has a leak in either the hose or the check valve. How do I access it to fix?
Thanks for any advice or directions.
Tom
irish01 is offline   Reply With Quote
Old 02-07-2016, 06:10 PM   #2
Campfire Master
Not familiar with your rig, but I would look in the vanity around or behind the bathroom sink.
John
AVid is offline   Reply With Quote
Old 02-07-2016, 06:47 PM   #3
Left Coast
If it's a leaker, do away with it and go to HD or Lowes and get a brass one for a house....cost more, but will never leak again..
Old 02-07-2016, 07:35 PM   #4
Canadian Member
itat's Avatar
Tom
Is there a cabinet or access panel inside where the flusher connection is located on the outside?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 02-07-2016, 08:09 PM   #5
Each model unit can be different. Mine was in the back of the bathroom linen closet, midway up in the closet. There was a large hole in the back of the closet. I know it's called for by code but I rip it out. The leakage liability is just too much risk.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 02-07-2016, 08:29 PM   #6
Canadian Member
itat's Avatar
DO NOT remove the check valve (aka backflow preventer)! It's there to prevent anything nasty from the black tank from backing up to the potable water supply!
If you absolutely want to remove it from inside, use one on the connection port.
Old 02-07-2016, 09:01 PM   #7
- never flush the blackwater tank with out an external check valve and never use a potable water source to flush. Any internal vented check valve can leak and destroy your trailer. Been there and had that happen, twice.
William & Sara
Old 02-07-2016, 09:17 PM   #8
What water source do you use when at a FHU Site for BTF? Youroo!!
youroo is online now   Reply With Quote
Old 02-07-2016, 09:28 PM   #9
Left Coast
X2....Maybe the pedestal supply isn't portable...
Old 02-07-2016, 09:34 PM   #10
Most dump stations have a separate water source for flushing. I don't flush unless going into storage. I mean, otherwise I will just be filling the tank with more stuff anyway.
William & Sara
black, black tank, black tank flush, tank
