Old 06-02-2013, 08:11 PM   #1
Loringj's Avatar
Blue hose under kitchen slide
2014 36CKTS has a blue hose with a shut off valve behind the rear tire. Any one have an idea it's purpose?
2014 36CKTS
2012 Ford F350 SRW
Days Camping since delivery 18
Loringj is offline   Reply With Quote
Old 06-02-2013, 08:25 PM   #2
Dave_Monica's Avatar
It sounds like a low point drain for cold water...should be a valved red line for the hot water also.
Dave
Old 06-02-2013, 08:27 PM   #3
Rrickim63's Avatar
Low point drain most likely. You can drain any water in the cold water lines before winterizing.
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 06-02-2013, 08:33 PM   #4
On my 30RL my drain for the fresh water tank is there
spock123 is online now   Reply With Quote
Old 06-02-2013, 08:35 PM   #5
Loringj's Avatar
I have red and blue near the front. I thought they were low point drains. This is only blue and in the rear with a shut off valve.
2014 36CKTS
2012 Ford F350 SRW
Old 06-02-2013, 08:47 PM   #6
QCCowboy's Avatar
Sounds like a fresh water tank drain.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 06-02-2013, 08:48 PM   #7
Former Full Timer
Duckogram's Avatar
There are 3 "valves" if you have the residential reefer. White push pull is for the ice maker. Petcock is for the fresh water tank drain and the vertical one is your low point drain. All 3 are blue on my '12.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 06-02-2013, 08:58 PM   #8
Loringj's Avatar
Fresh water drain, thanks.
2014 36CKTS
2012 Ford F350 SRW
Old 06-03-2013, 06:41 AM   #9
ret2006's Avatar
X2
It is the fresh water tank drain on my 34 RLSA. Should be a small tube close by that is the fresh water tank over-flow.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 06-03-2013, 03:19 PM   #10
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
Same on my 2013 36CKTS
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
