Old 01-25-2016, 07:13 PM   #11
camaraderie's Avatar
Originally Posted by Gpa-Dave View Post
I am hoping the idiot lights that show charge and tank levels works well enough to keep me up to speed.
If you are going to be boondocking with a rez fridge you are absolutely going to need a real battery monitor like the Trimetric or Victron or you will soon become a very UNHAPPY camper if you rely on idiot lights OR a voltmeter reading. Search for Victron or Trimetric here for more details.
BTW....I too would pay for a gas fridge for boondocking rather than put up with the hassle of a rez & charging. Occasionally is one thing but if that is how you camp most often then gas is the way to go.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 01-25-2016, 07:57 PM   #12
I have a huge residential fridge, a dedicated 2000 watt inverter, an additional 1000 watt inverter (TVs, cell phones, computers, CPAP, etc) and 4 12 Volt deep cycle batteries.
Just installed a Trimetric and would never be without it. No more worries...and the reefer is really no problem. Run the genny a couple of hours a day, but since I am doing that anyway I have an electric coffee maker and don't worry about starting up for a half hour more since it always is putting amps "in the bank." With the trimetric I always know where I stand.
The panel idiot lights...are for...idiots.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 01-25-2016, 08:13 PM   #13
Originally Posted by Explorer1016 View Post
My fridge is a 10 cu. ft double door Dometic 2 way. I know Norcold and Dometic both make a larger capacity double door unit (side by side) for the bigger class A rigs and towables for large families.
I installed a Trimetric 2030RV system monitor for my batteries. With the push of a button I can monitor every state of my batteries, volts, capacity, amp draw, charge rate etc. The indicator lights could be misleading when it comes to something as critical as battery state. My monitor didn't cost that much (maybe $150.00) and it was very simple to install. My battery compartment is right by my entry door so I installed the monitor on the side of my sink base which is right at the steps and by my water heater controls and slide controls. Bogart Engineering | manufacturer of the TriMetric battery monitor which measures volts, amps and amp-hours for battery systems
Trimetric products are a great way to monitor many things about your battery including Ah-hours both in and out of the battery(s).
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 01-25-2016, 08:16 PM   #14
We have observed several large class A motorhomes that travel with a Honda 2000 generator to avoid operating their built-in diesel generators while boondocking. Quietly provides power for recharging and refrigerator operation. Also eliminates noise and vibration of the internal generator.
Old 01-25-2016, 08:29 PM   #15
ttanous's Avatar
I have the whirlpool refrigerator. It is the 20 cubic foot. I have traveled 10 hours with no problems with inverter. I have installed a meter in the basement by taping off the hot side of the light in the water closet. I am comfortable based on my experience going 15 hours without any issues. Hope this helps using the inverter supplied by CC. This is with 4 - 6 volt batteries.
ttanous is offline   Reply With Quote
Old 01-25-2016, 08:58 PM   #16
Bluepill's Avatar
My Samsung 25 Cu.Ft French Door refrigerator uses an average of 2KWH per day measured on the 120 volt side. This is with inside temperatures averaging 72 degrees. It will use more as the temperature goes up. That equates to 180 Amp. Hr. of battery use every 24 hours. (180 x 12 volts x 92% efficiency for the inverter). Since you do not want to discharge your batteries more than 50%, it requires 360 Amp. Hr. battery capacity just for the fridge. The size of your battery bank and the exact usage of your particular fridge will determine your usable run-time.
2008 Itasca Meridian 37H
Old 01-25-2016, 09:38 PM   #17
bikendan's Avatar
The fridge is just another item to draw down your batteries and forcing you to run the generator. When we boondock which is most of the time, I don't want to hear the generator running, so I am satisfied with the gas/120v absorbent fridge. Our works great and stays cold. it doesn't use very much propane and doesn't have much draw on my batteries. Remember, if you camp in cold or cooler weather, you will need to eventually run the furnace. Now you have 2 appliances that will draw fairly heavy from the batteries.
This is just my opinion. I would not buy the residential fridge. If it were me, I would opt for the large capacity 2 way fridge and pay the additional money to have it swapped into the RV. Then you are not dependent on running your generator or keeping the rig plugged in to keep your batteries charged up.
x2!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-25-2016, 11:56 PM   #18
X2 - (at least)
If you are going to do any boondocking you will want this item made by Bogart Engineering. Trimetric 2030RV. Easy to install and it's an excellent way to monitor your battery in all the ways you will need. I looked at many different ones before settling on this one based on info on this forum.
Sure glad I did.
2002 GMC Sierra 2500HD Duramax
2008 Rockwood Sig Ultra Lite 8315SS
Livin the Life is offline   Reply With Quote
Old 01-26-2016, 08:17 AM   #19
Go Solar
On our houseboat, we use a Honda 2000 at the end of a 100 ft. 10 ga. extension cord to run our freezer (frige is gas). Nice and quiet. We run it about 6 mehours a day and that is enough even at 100 degrees. Google HandyBob's Blog and it will tell you everything you need to know about solar. I use solar on my trailer, and it runs everything but the AC and microwave on a 100 watt panel and two batteries. The Trimetric battery monitor is the right answer, even if you don't go solar.
mnoland30 is offline   Reply With Quote
Old 01-26-2016, 10:26 AM   #20
Wow! Thank You! I would need an electrician to install, but that is not hard. Thanks again!
GpaDave is offline   Reply With Quote
fridge
