I am running off my 4 six volt batteries while boondocking. I have a number of questions that I am hoping others with 36CKTS can assist:
1. When fully charged my batteries read 12.8 volts. After using about 12 hours, the idiot lights show 3 lit, 2/3 charged. The reading off my lippert control panel says 11.9 volts. What should the reading show for 50% battery charge?
2. I have a residential refrigerator which uses a 1000 watt inverter while on battery power. When I turn on my 5.5 kilowatt generator to charge the battery do I need to turn off the inverter which has an automatic transfer control?
3. With those with the same set-up, how long do I need to run the generator to fully charge the batteries from 50%?
4. Finally, how long can I expect the generator to run off of a 30 pound propane tank?
Thank you in advance for your assistance.
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Look at 12 volt side of life. At 11.9 it is at 40%.
Above are the links for "The 12 Volt Side of Life.
If you really want to make life easy while boondocking, install solar. I did this winter and it was the best purchase I've made for my 36CKTS. Only time I run the generator is to use the microwave and once when it was cloudy and raining for 3 days.
Tom
2015 Chevrolet Silverado LTZ 3500 CC DRW Diesel
2014 Cedar Creek 36CKTS
The generator will use approximately this much propane: No load 1.8lb/h, Half load 3.3lb/h, and Full load 4.6lb/h. Yes it is on the high side but it is a propane generator.
As mentioned solar is the way to go if boondocking.
Tim and Bev
2013 Cedar Creek 34RLSA gone trying to find my way back, Magnum 2800w inverter, 560w of solar.
2020 F-350
