Old 11-02-2015, 07:34 AM   #1
Buying a 04 Cedar Creek 37CKQS
We are considering buying a 2004 37CKQS. We may need to spend some winter months in a cold climate. Is this a good choice for this kind of weather?
Thanks,
Kenny and Peggy
grumpyt55 is offline   Reply With Quote
Old 11-02-2015, 07:46 AM   #2
Former Full Timer
Duckogram's Avatar
If it has the cold wx package, heated tanks and dual pane windows it could be reasonably comfortable and function in sub-freezing temps. Also keep in mind that it is past its designed service life.
Edit: You might also consider some "skirting" to keep the cold wind out from under the belly.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 11-02-2015, 08:58 AM   #3
Designed service life? Thats a new one.
We own a 2005 thst does quite nicely in cold weather. Mind you, no matter how new or old RVs are just not as well insulated as a S&B home will be. Below about 40 you will use lots of heat, either electric heaters or propane furnaces. Add frozen water lines, frozen dump valves it can become very difficult for the uneducated RVer. We did it a couple years ago in the Columbia River gorge. 2 feet of blowing snow, lows around 10. I learned a lot. Mainly its cheaper to move to a warm climate. 150 dollar a month electric bills and 75 dollars a week propane became the norm.
CCs are among the best fivers on the market, but you will still be cold.
donniedu is offline   Reply With Quote
Old 11-02-2015, 09:38 AM   #4
With an older camper there are concerns. The obvious is you dont know the history of it since you havent had it since new. A solid PDI of the unit as it sits now will ease this concern.
The main question is how much experience do you have, not to be rude by any means but if you are a novice it might be harder to see what (if anything) is wrong with the unit. If you are experienced you will know what to look for.
I wouldn't totally write this one off but if you aren't experienced take someone with you.
For the direct question of cold weather, it will make it through the winter it just may cost you some money in heating. You will be running the heater and will probably use space heaters. See if it has a cold weather or climate package. This usually has tank heaters, maybe an insulation upgrade, add some skirting and you should be ok. You may need some other items to make it easier like a heated water intake hose, you may need to add heat tape to the pipes.
I am not sure what the other other poster meant by "service life", I am curious as to what they meant.....
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 11-02-2015, 09:42 AM   #5
I suspect he was trying to say that any RV over three years old was worn out! Not everybody has or is willing to part with the cash for a new RV. And some of us are satisfied just to have an RV.
Old 11-02-2015, 03:16 PM   #6
Boso's Avatar
Cedar creek
I wouldn't want to be in cold climate in any Rv Cedar Creek certainly would not be an exception Get some warm sleeping clothes
Boso is offline   Reply With Quote
Old 11-02-2015, 04:16 PM   #7
Go to Florida below the frost line. Hunt for an RV park where utilities are included. $150 a month in heat and cool are not unreal. Get reservation right away.
James Briar is offline   Reply With Quote
Old 11-03-2015, 08:09 AM   #8
If you are staying in one spot check out a 100gl tank. It's a lot cheaper that way. That way someone will keep it filled up for you
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 11-03-2015, 08:37 AM   #9
Being full timers in an 04, 34ft, CC, didn't notice it passing its Designed Service Life. Unit is exceptionaly well built, could use more insulation for the colder periods, but has serviced our needs very well, travels well to the South during the Winter Months and has not required much in the way of repairs over the 9 years or so that we have owned it. Our unit has heated tanks but only single pane windows.
Skirting and heated water intake line would be a necessity in temps below freezing especially in windy conditions.
kenenn is offline   Reply With Quote
Old 11-03-2015, 09:25 AM   #10
We have an 03 30RLBS that has been a great 5er. I'm not sure that I buy into the comment of a unit that age being "beyond its serviceable life." In some ways, I think trailers of that era are better built than those today. But in regards to cold temps, if it gets brutal, you'll have to work to keep the cabin comfortable. We use electric heat most times and will kick the furnace on in the morning when first waking up if it's really cold and I'm in central Arkansas. As some have mentioned, for long term comfortability, you may be better off closer to the gulf during winter months.
philobeddoe is offline   Reply With Quote
cedar creek
