07-17-2016, 04:59 PM
Cadet wall heater
I have the cadet wall heater installed in our bedroom. My question is, how do you shut the power off to it, when you don't need it running. I currently shut it off by shutting the fuse off, it is hooked to the washer fuse. In the online manual, it states it has a 3 way switch, heat/off/fan, mine only says heat/fan. So now the way it is, when I want to run the washer, the fan will blow air. Any ideas?
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
400 watt Rich solar on top,200 watts of suitcase
07-17-2016, 05:09 PM
Was this something installed by the dealer?
B and B
07-17-2016, 05:13 PM
yes
If I remember, I'm calling the dealer tomorrow.
not a big deal, but to completely shut it off, I have to do the breaker.
07-17-2016, 05:20 PM
Mine has never come on. It's in 'off' position all the time now. Not sure why the on/off switch isn't turning yours off.
FROG AR-0019-242
07-17-2016, 06:12 PM
not sure where the on/off switch is at. I have a plus and minus switch, goes from 1 to 3 speed for the fan speed.
Ill take a pic and post of the front of the fan/heater
07-17-2016, 06:36 PM
OK you made me go look. I have the fan speed + and - also.........but I have two other buttons.......one is fan speed and it is set to 0. Thus, it's not on. You are right, there is no on/off switch per se, but if I turn the fan speed to zero, it doesn't come on.
I bought mine in May, so I haven't had this heater on at all yet, actually.
FROG AR-0019-242
07-17-2016, 06:58 PM
on the display, it only goes 1,2, or 3, no zero
07-18-2016, 08:31 PM
Here is a pic
07-18-2016, 08:32 PM
Another one
07-19-2016, 05:58 PM
Turned mine on heat and fan went off
07-25-2016, 07:16 AM
yep, thats what I did, so I guess thats how you shut the fan off.
