Old 07-17-2016, 05:59 PM   #1
wls
Cadet wall heater
I have the cadet wall heater installed in our bedroom. My question is, how do you shut the power off to it, when you don't need it running. I currently shut it off by shutting the fuse off, it is hooked to the washer fuse. In the online manual, it states it has a 3 way switch, heat/off/fan, mine only says heat/fan. So now the way it is, when I want to run the washer, the fan will blow air. Any ideas?
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
wls is offline   Reply With Quote
Old 07-17-2016, 06:09 PM   #2
CANADA FROG RALLY 2017
B and B's Avatar
Was this something installed by the dealer?
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 07-17-2016, 06:13 PM   #3
wls
yes
If I remember, I'm calling the dealer tomorrow.
not a big deal, but to completely shut it off, I have to do the breaker.
Old 07-17-2016, 06:20 PM   #4
BandJCarm's Avatar
Mine has never come on. It's in 'off' position all the time now. Not sure why the on/off switch isn't turning yours off.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-17-2016, 07:12 PM   #5
wls
not sure where the on/off switch is at. I have a plus and minus switch, goes from 1 to 3 speed for the fan speed.
Ill take a pic and post of the front of the fan/heater
Old 07-17-2016, 07:36 PM   #6
BandJCarm's Avatar
OK you made me go look. I have the fan speed + and - also.........but I have two other buttons.......one is fan speed and it is set to 0. Thus, it's not on. You are right, there is no on/off switch per se, but if I turn the fan speed to zero, it doesn't come on.
I bought mine in May, so I haven't had this heater on at all yet, actually.
FROG AR-0019-242
Old 07-17-2016, 07:58 PM   #7
wls
on the display, it only goes 1,2, or 3, no zero
Old 07-18-2016, 09:31 PM   #8
wls
Here is a pic
Old 07-18-2016, 09:32 PM   #9
wls
Another one
Old 07-19-2016, 06:58 PM   #10
Turned mine on heat and fan went off
swannie is offline   Reply With Quote
heater
