Old 08-21-2013, 07:24 AM   #21
TURBS's Avatar
Originally Posted by Duckogram View Post
No can do. The tube, which is the piston rod, fully retracts leaving no room for a collar.
Makes sense.
Do you have pictures of said foot and jack?
Old 08-21-2013, 08:07 AM   #22
Former Full Timer
Duckogram's Avatar
Originally Posted by f1100turbo View Post
Makes sense.
Why certainly...
ID:	38325   Click image for larger version
ID:	38326   Click image for larger version
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 08-21-2013, 08:17 AM   #23
Platokidd's Avatar
Originally Posted by platokidd View Post
Okay you guys has me thinking again about my lacrosse.
I have lippert electric stabilizing jacks front and rear. Yes its nice just to push a button to move them up and down. But for a stable feel I dont think there all that great.
My wheels are too far a part for the wheel X lock.
I use what I have read on another thread was not a good idea as well. Thats plastic wheel chocks. I hammer in with a mallet. I have wood ones but I wanted to cut down on the weight I am carrying.
I also have thought about the slide-out jacks. Just to take them to short of the Mississippi not Kansas or Omaha. (light touching) Kind of like what I do with my wally world jacks I use under my step. Just light contact to firm things up a bit. I have also thought about the bars you can add to your jacks that run to the frame.
Anyway my unit when set to stable ...just aint stable enough for my liking.
May be I should add a couple of scissor jacks??
Anyway I thought I would throw this out there at the peanut gallery and see what comes back
This site is really awsum, I have learned so much here in a year!!
Carl
Okay..let me simplify this..what should I try first??
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 08-21-2013, 08:22 AM   #24
TURBS's Avatar
Strong arms imo.
Bal brand is really inexpensive but work just like the expensive ones. Again imo.
Your results may very.
Turbs
Old 08-21-2013, 08:23 AM   #25
You will just have to either bolt thru the round pad or weld the lower mount for the struts.
Old 08-21-2013, 08:26 AM   #26
TURBS's Avatar
Why certainly...
Id fabricate a bracket or have a machine shop make one that goes around the very end of the cylinder that clamps tight around the cylinder then has a tab coming off of that's to mount your strong-arm to .
My opinion.
Turbs
Old 08-21-2013, 08:26 AM   #27
TURBS's Avatar
Lower pad can turn as he suggested which won't do him any good.
Old 08-21-2013, 08:37 AM   #28
Is it necessary for the pad to turn? Once a mounting tab is welded or bolted to it, it will align with the strut and when it has wt on it, will not turn.
Old 08-21-2013, 08:43 AM   #29
TURBS's Avatar
Not sure.
Would be a pain to line pad up everytime if it did turn slightly while in transport.
Old 09-11-2013, 11:11 PM   #30
OL Creeker's Avatar
It was suggested by a Lippert rep. that after being at a site for a week, the level up system should be reactivated to re level the coach, if you're staying put.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
