Old 08-18-2013, 07:58 AM   #1
BoatDude's Avatar
Camper stability.
We have the 36 ckts with the level up system. But we still have issues with camper shake while walking around inside. I read once that no additional support jacks are needed with the level up system. Also do not put support jack under the slide outs. We are sitting on a solid gravel pad with all tires on the ground after level. Since we park our cc in a seasonal site....think its ok to add some support jacks under the slide outs? Any thought on this? Our old camper.. park model..was solid as a rock and sitting here for years.
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 08-18-2013, 08:27 AM   #2
Former Full Timer
Duckogram's Avatar
There are a few things I did to help stabilize the rig for longer term locations.
I put blocks under all of the jacks so there was minimal extension of the legs. That helped quite a bit.
Next I put two of those screw type aluminum jack stands (4 for $40 at Wally mart) under the ends of the trailer hitch crossmember.
Finally, I deflated the TrailAir and put a kingpin stabilizer on.
Lastly, I made a step support out of two old x-chocks. (I have the ETD Quadrasteps)
Voila, solid as a rock.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 08-18-2013, 08:46 AM   #3
TURBS's Avatar
Slide out supports are not recommended.
Old 08-18-2013, 11:00 AM   #4
BoatDude's Avatar
I've done everything you've mentioned but the stabilizer under the pin. I look into adding one....do you have a recommendation. ..for a sturdy one?
2013 36 CKTS
ReTrax Pro Cover
Old 08-18-2013, 11:09 AM   #5
Fulltime family RVer
Stabilizers under the slide outs is just a bad idea. You'll still have movement when people walk around the inside, but the slide won't move and will cause stress on the point where the slide connects to the camper.
Many people are using JT's StrongArms (or something similar to the triangulation stabilizers) with good benefits. Between the wheel wheel-chocks also help. And finally, with those 2- people then put scissor jacks under the camper near the axles to take a bit of bounce out of the suspension.
My next step is to try the scissor jacks and see how it goes.
Old 08-18-2013, 11:24 AM   #6
Problem Solver
sugarbear's Avatar
I have a 2007 36BHLE with Big Foot Jack System. My rig is very stable after adding X-Chocks between the wheels, adding scissor jacks at the back of the trailer and a king pin tri-pod to stabilize the front.
2007 Cardinal 362BHLE, Bogfoot Leveling System, Trailair Pinbox, Center-pointe Air Suspension
2014 Dodge 3500 MegaCab w/ 6 spd auto and air ride suspension
sugarbear is offline   Reply With Quote
Old 08-18-2013, 02:25 PM   #7
BoatDude's Avatar
I dont have the tire locks....they may help also. Thanks.
2013 36 CKTS
ReTrax Pro Cover
Old 08-18-2013, 04:52 PM   #8
Former Full Timer
Duckogram's Avatar
Just about any king pin stabilizer that is high enough will work. Most are rated for 5000 lbs. Emphasis on the high enough.
Level-up 5ers sit higher than most so you may want to break out the tape measure.
Ependydad: speaking of level-up, I don't think there is an application for JT strong arm and alike that is compatible. I've never seen it either... Just sayin.
Old 08-18-2013, 05:14 PM   #9
We put scissor jacks on the 2 x 4 tubing in front of the axles on Herk's 5er and haven't heard if he felt like they helped.
Old 08-18-2013, 05:30 PM   #10
Brother Les's Avatar
The 'stabilizers' on my camper imo are junk and I may remove them.The scissors jacks will fix your side to side movement. The wheel X lock will stop the front to back rock movement. We only have one on one side and it fixed all of the front back and forth movement.
Brother Les
