Old 06-04-2016, 11:13 AM   #11
I didn't realize that this was even a problem. When I changed out tires a couple of years ago I asked them to install steel valve stems. I have aluminum rims and they installed steel valve stems. Roberts Tire in Mesa, AZ.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-04-2016, 02:45 PM   #12
GreenImp's Avatar
Send a message via MSN to GreenImp
I used Haltec TV-575-HP stems which are 3/4" tall and use a top mounted nut. Purchased them from Grainger. I did have to grind the washers down to a slightly smaller diameter to fit in the recessed hole of my Rockwood's wheels. Very pleased that the TST 507 sensors are tucked inside of the wheels due to the very short 3/4" stems.
HALTEC Clamp-In Tire Valve,1 In,Pk 5 - Tire Valve Stems and Cores - 33W538|TV-575-HP - Grainger Industrial Supply
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 06-06-2016, 12:28 AM   #13
dieselguy's Avatar
Just ask around for Enkei style metal valve stems for a .453" rim hole. Remove the two nuts from the stem as well as the first half of the rubber grommet. Install the valve stem with the other half of the grommet down in the stem hole. Install the previous half of the grommet, washer, and two lock nuts inside the rim. The hole is too small for the other type of metal valve stem that has an exterior lock nut.
dieselguy is online now   Reply With Quote
Old 06-07-2016, 05:58 PM   #14
steelpony5555's Avatar
Why worry bout metal stems.....unless you have the 110 lb wheels and tires then you don't really need them. Hopefully you didn't buy Goodyear Marathons as your new tires cause when you have a blow out you may lose those metal stems.... If you bought Marathons take them back and get reimbursed. Buy a set of LT E rated truck tires or if you buy Goodyear G614's then you can use those metal stems...
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 06-07-2016, 06:13 PM   #15
wmtire's Avatar
The OP stated in his first post that he is installing metal clamp-in stems because he is attaching TPMS sensors to them.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-07-2016, 06:34 PM   #16
Witch Doctor's Avatar
Originally Posted by acadianbob View Post
I had the same experience. The aluminum rim would not allow the metal stem to fit.
I also had the same problem, the tire dealer ordered the wrong stems, the nuts where to big, he then reorder another set that the nut did fit through the rim from Napa. I think it was a 3/8" nut don't remember for sure. But the size of the nut was the problem I have the "S" series rims....They make all different sizes and Napa can get them... If you have a TST system you do need that metal solid bolt in stem, I do not really know what a metal clamp on stem is to be honest...Maybe the same thing but different terminology.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 06-09-2016, 02:52 PM   #17
CC75's Avatar
Originally Posted by CC75 View Post
I have decided to buy:
4 of Xtra Seal 17-416 - Bolt-In Valve | O'Reilly Auto Parts
and 4 of Xtra Seal 17-428 - Bolt-In Valve | O'Reilly Auto Parts
Hopefully, one of these sets will do the trick.
Update on the thread. I bought the sets above. I called a chain tire store, and they did not seem to have any idea whether they could install a bolt on metal valve stems. He told me all the valve stems had metal in them, so I decided to call another store. With a suggestion from a fried, I located a tire store 30 miles up the road from me that works on RVs. I took the 4 wheels and the stems to them. They mentioned that if I did not mind they would use their own stems that they are familiar with. They installed the stems with the TPS sensors and balanced the wheels. All seems to work. I have the display sitting on the dining room table with the rig in front of the house. The transmitter and receiver work fine from that distance; about 20 yards.There is about a 5 psi difference from morning to late afternoon with the help of the Texas sun.
When I installed the wheels, I torqued the lugs to 110 ft-lbs. I had read somewhere that Aluminum wheels should be torqued to 90 ft-lbs.
Would the additional torque cause any damage?
CC75 is offline   Reply With Quote
Old 06-09-2016, 04:06 PM   #18
Not that I know of, you should be fine....
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-09-2016, 04:08 PM   #19
fmc
fmc's Avatar
I bough mine on eBay for the small hole size.
fmc is offline   Reply With Quote
wheel
