Old 08-13-2013, 08:48 PM   #1
Cowboy 54's Avatar
Caring for rv tires
I was thinking if you sprayed your Rv tires with rubber roof conditioner would if it would help I put covers on mine but thinking of spraying them too !
Cowboy 54 is offline   Reply With Quote
Old 08-13-2013, 09:48 PM   #2
mlatter's Avatar
I'm not sure about the roof conditioner, but I have heard that the covers inhibit airflow around the wheels which results in brake system corrosion and other issues.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 08-13-2013, 09:54 PM   #3
Tire treatment
Old 08-14-2013, 06:36 PM   #4
Former Full Timer
Duckogram's Avatar
After I tossed a set of Michelin LT's with 6000 miles on them I started using 303 and cotton lined white covers. Now that we are on the road, I no longer use the covers. 303 is great for the slide and compartment seals as well. I don't use it on the EPDM as I have not looked into that or contacted Dicor as of this date.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 08-15-2013, 12:31 PM   #5
mlatter's Avatar
eShine Canada: 303 Aerospace Protectant w/sprayer (16oz)
Looks like it's good for the EPDM roof too.
I'm going to order some.
Old 08-15-2013, 09:12 PM   #6
Former Full Timer
Duckogram's Avatar
Interesting claim from a retail sales outfit. I'll wait till I have time to verify that with the manufacturer.
Old 08-15-2013, 09:55 PM   #7
mlatter's Avatar
Well, as it turns out, the claim is from Dicor themselves. I did find something very interesting though.
In one document, you can scroll to the bottom and see this:
Q: The rubber roofing wraps over slightly on both sides of my RV and you can see it from the ground. It gets dirty and doesn't look good. What can I do about this?
A: Clean the area and treat it with a product that will repel soiling and is safe for EPDM. One product that performs and lasts well, is safe for EPDM and is commonly available at RV stores is 303 Protectant.
http://www.google.ca/url?sa=t&rct=j&...50768961,d.dmg
In another, it changes to this:
A: Clean the area and treat it with a product that will repel soiling and is safe for EPDM. One product that performs and lasts well, is safe for EPDM and is commonly available at RV stores is Dicors RP - 320S Rubber Roof Guard Protectant.
Both documents claim to be from Dicor:
Dicor Corporation P.O. Box 1806 Elkhart, Indiana 46515
Tel. (574) 264-2699 Fax (574) 293-2017 Toll Free (800) 837-2059
Looks like Dicor's Rubber Roof Guard Protectant could be just relabeled 303 Protectant, but at the very least, each is safe for your roof.
Old 08-15-2013, 10:00 PM   #8
Cowboy 54's Avatar
Well if good for your rubber roof why wouldn't it be good for your tires !
