Old 12-14-2016, 12:27 AM   #1
Kenstrucks's Avatar
CC 34rl 2017 outside plug GFCI
Have a new 2017 CC 34rl and the basement and outside outlets are not working. All the breakers are good. Outside plug says it is GFCI protected but does not have the switch to reset. Anyone know where the GFCI reset switch is for those two outlets? I have checked all the ones I can find inside and all show good.
Ken in Tacoma, WA
2017 RAM Laramie 3500 Mega-Cab DRW 4x4 Cummins, Aisin, 3.73
2017 CC Hathaway 34RE Touring Edition
- 2016 2nd half of year days camped = 34
- 2017 camped days = 38
- 2018 on track for 40 days camping
Kenstrucks is offline   Reply With Quote
Old 12-14-2016, 08:27 AM   #2
brusso's Avatar
If you have a central vacuum under the steps it plugs into an outlet. I cannot remember if they are all connected or if it is a gfi.
Brian & Terri
Samson (Chocolate Pom)
Full timers
2008 F350
2017 CC Champagne 38EL
2006 Salem Sport 32 SRV Toy Hauler (still have)
brusso is offline   Reply With Quote
Old 12-14-2016, 01:04 PM   #3
Kenstrucks's Avatar
Yea. I was thinking the same but the vacuum is working. Swinging by the dealer to ask they today.
Ken in Tacoma, WA
Old 12-14-2016, 01:33 PM   #4
Retired JSO's Avatar
The GFCI in the bathroom or kitchen is tripped as they are wired together. If you are sure the inside ones are good, trip and reset just to make sure.
Retired JSO is offline   Reply With Quote
Old 12-14-2016, 05:23 PM   #5
Kenstrucks's Avatar
Checked kitchen and bathroom GFCIs and they are good. I did trip both and reset. Talked to dealer and they suggested a couple things to check. Will do this this weekend and report back. This could be a not connected issue. Ive never tried those outlets before but should have been checked at PDI supposedly.
Ken in Tacoma, WA
Old 12-16-2016, 05:30 PM   #6
Kenstrucks's Avatar
Have to admit this one was user error. I was able to get out to the trailer today with my plug checker, not just the heater I was trying to plug in, and the plugs showed good to go. After scratching my head for awhile I discovered the smaller heater I was wanting to put in the basement during our cold snap had the tip over switch on the bottom plate outside the hearer (small plunger type switch) and I was not setting it down when I tried it. Was just holding. Set it down on a flat surface and it worked on the plug in the basement.
Thanks for the suggestions on what to check.
Ken in Tacoma, WA
Old 12-16-2016, 06:42 PM   #7
Decon Blue is offline   Reply With Quote
