Old 12-22-2015, 01:10 PM   #11
Airdale's Avatar
I print this information about the manufacturers hitch weight whenever a thread about it keeps running.
The RV trailer manufacturers hitch weight serves one purpose and itís establishment is mandatory. Itís used to keep the trailer manufacturer honest about the trailerís GVWR. Once the trailer manufacturer establishes the GAWR values they must also establish a hitch weight. Once established and published they cannot change it. However, they are allowed to use a range. When that is done the lowest value in the range must be used in the trailer weight calculations. According to FMVSS the established hitch weight is added to the trailerís total GAWR. The sum must equal or exceed GVWR. End of story.
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 12-22-2015, 08:37 PM   #12
keith52's Avatar
Wink
Originally Posted by JohnF View Post
Okay, I found the problem. If you click on the 36ckts floor plan on the Forest River site you will see the specs on it. It shows the uvw at 12,670 and the pin weight at 2407. If you do the math that gives you an 18.99 percent pin weight. My old calculator is on its last leg and lost the left side of the number 8 which made it look like a number 3, thus 13.99 or 14 %. Okay, I'm not losing it yet! ��
Nice shot John!!
keith52 is offline   Reply With Quote
Old 12-28-2015, 01:07 PM   #13
SlowrideHD's Avatar
Hey! How are you? I know how to pronounce your hometown (correctly). I went to school at Houston, class of '71 (also know how to pronounce it!!)
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
weight
