Old 05-08-2016, 09:22 AM   #1
Lilredram's Avatar
Question CC Silverback, is there a built in water filter???
Hi all
Just picked up 5er and have to dewinterize it. Is there a built in water filter? There isn't a Visible one so is there a hidden one?
It's a CC Silverback 29RE. Any help would be greatly appreciated.
Thanks RonG
__________________________________________________ ____
2017 CC Silverback 29RE / UVW (dry wgh't.)=10,705 lb
Pin wgh't.=1,985 lb / GVWR=13,985 lb
2016 Ram Delmonico Red 2500 CC 4x4 6.7L Cummins
with rear air suspension 68RFE 6spd Auto 3:42 axle
Gvwr=10,000 lb GCWR=23,300 lb payload
Lilredram is offline   Reply With Quote
Old 05-12-2016, 10:15 AM   #2
arpipeliner's Avatar
It would be below where you hook up your water hose. Have heard that some don't have them now.
arpipeliner is offline   Reply With Quote
Old 05-12-2016, 07:16 PM   #3
How long do they run on tank of fuel with your AC s running
hughd033 is offline   Reply With Quote
Old 05-12-2016, 07:38 PM   #4
They no longer come with filters
denville is offline   Reply With Quote
Old 05-12-2016, 07:54 PM   #5
Lilredram's Avatar
That's what I thought
RonG
Old 05-17-2016, 01:39 PM   #6
Question on WATER FILTER.... After this LAST FILTER DIES, considering discarding it and leaving the housing on for the remainder of the year, without a filter cartridge.
I plan to take the housing off and sterilize it AND go back to the old method of in line hose filters at the outside point of water source.
Plan to do that until I can see how to use those shark bites and by pass it permanently.
Any concerns?!
SilverbackMel is offline   Reply With Quote
Old 05-17-2016, 01:49 PM   #7
Georgia Frog Rally 2018
aceinspp's Avatar
Any concerns?!
I have never installed the filter that came with the system. Just left it out and use inline at out side water connection. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 05-17-2016, 03:08 PM   #8
RJD
Tnx. Thought that will work out ok.
Old 05-17-2016, 03:16 PM   #9
Ejs4029's Avatar
X2 Never installed my filter either...Just use an external inline filter now....Need to look into removing the canister before it unscrews or breaks.
2015 Dodge Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Ejs4029 is offline   Reply With Quote
Old 05-17-2016, 03:37 PM   #10
Kaadk's Avatar
We use ours all the time, never had a problem with it unscrewing or anything. Just used the right replacement filters and made sure it was snug each season.
However, now that I've gotten around to buying a set of Pex crimps (to deal with a different issue elsewhere in the trailer) I am considering installing a couple of valves to mimic the WH bypass so I can bypass the filter housing during winterization. I figure that'll save me about 1/2 gallon of antifreeze and prep me to bypass the filter if whatever ya'll have been worried about does eventually happen to me.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
water, water filter
