Old 07-20-2016, 10:59 PM   #1
ttanous's Avatar
CC Wheel Bearing Grease Recommendation
I am planning this weekend to grease the wheel bearings. Anyone using the high temperature grease? Can this also be used for the grease zerts on the shackles? Have used high temperature grease on my other 5th wheels before. Just wondering what everyone is using.
Tom
2016 Ford Power Stroke F350 Lariat Crew Cab Long Bed Dual Wheel
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 07-21-2016, 08:28 AM   #2
dieselguy's Avatar
Page 7 if you want to go by manuf reccomendations
http://www.primetimerv.com/download/...andService.pdf
dieselguy is offline   Reply With Quote
Old 07-21-2016, 08:34 AM   #3
rattleNsmoke's Avatar
Just about any decent wheel bearing grease will do. I tow between 65-70 mph on average so most work for me. I believe last time I re-packed the bearings I used Pennzoil full synthetic. It was on sale at Napa.
1988 Harley Softail Custom "The Fireman"
rattleNsmoke is offline   Reply With Quote
Old 07-21-2016, 08:36 AM   #4
I use Mystik NLGI #2 High Temp multi purpose Lithium Complex. Working temp of -10f to 325f. Recommended for disc brake bearings. It is fine to use on the shackels too.
Are you pulling the drums and hand packing the bearings or pumping it in through the axle zerks?
Doug & Cindy
2014 36 CKTS: Titan Disc Brakes, EMS, Trav'lr
2016 Ram 3500 CTD 4x4 CCLB DRW: Andersen Alum II, Factory Rear Air Suspension, 3.73
DJNCJ is offline   Reply With Quote
Old 07-21-2016, 08:37 AM   #5
If you want to be a Rebel,use "Lucas Red & Tacky"! Youroo!!
Old 07-21-2016, 03:18 PM   #6
Wheel bearing puzzle
in the Dexter axle book, on P55, they mention using PERMATEX red on the seals on the EZ lube axles. I have never run across this requirement for packing wheel bearings. Does anyone know why?
mlawler506 is offline   Reply With Quote
Old 07-21-2016, 04:37 PM   #7
I presume you are referring to Loctite "red" ?
I have never used it on hub seals for any of my trucks, cars or trailers. Seals often come with a coating on the outside surface to act as a sealant. Loctite will obviously aid in holding the seal in place. To answer your question... I am unsure why it is needed. Dexter may have required it to "cover their *****"?? Just a guess.
Doug & Cindy
Old 07-21-2016, 08:35 PM   #8
mike.t's Avatar
"Are you pulling the drums and hand packing the bearings or pumping it in through the axle zerks"?
I too would like to know.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-21-2016, 08:43 PM   #9
I'm replying to the 2 prior posts/
There is red PERMATEX. It is for high temperatures. From another thread I started, it is needed to prevent the seals from popping if you inject grease via the zerk fitting of the EZ lube system.
The red PERMATEX is needed when you do a wheel bearing repack when you take the bearings out. If you are injecting grease via the zerk fitting, you have to hope the person before you used PERMATEX lest you have brakes that have very little friction.
Old 07-21-2016, 08:51 PM   #10
racer4's Avatar
These are Dexter axles, right? Not Lippert.
Find the Dexter Axle Service Manual at http://www.dexteraxle.com/literature1 , look for Service Manual for your axle capacity and download it. It has a page of grease recommendations, in the 800-8K LB manual look at page 53.
One of the greases Dexter recommends is Valvoline Multi-Purpose GM which is Valvoline part number VV614 in a 16 oz tube. That is what I have used for the last 28 years. It is easy to find, Advance Auto, O'Rielly, NAPA, etc.
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually 4.10 axle ratio Auto Flex Air Ride Rear Suspension
2017 Cedar Creek 36CKTS
racer4 is offline   Reply With Quote
wheel
