Old 10-31-2014, 05:36 PM   #21
DDC
DDC's Avatar
Originally Posted by f1100turbo View Post
Out of curiosity how does a two inch lift kit add 5,000 lb capacity?
Turbs
It's perfectly logical, make it higher so everything goes up.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is online now   Reply With Quote
Old 10-31-2014, 06:59 PM   #22
I could see how it works. The rear bump stops are further away from the axle. Takes more weight to make them bottom out.
goduc is offline   Reply With Quote
Old 11-02-2014, 06:15 AM   #23
Total Bliss's Avatar
I've read several replies on "air bag levelers", what are they?
2016 Silverado Dually
2016 Cedar Creek Champagne 38el
Total Bliss is offline   Reply With Quote
Old 11-02-2014, 06:26 AM   #24
Witch Doctor's Avatar
Firestone Air Spring Kits
Shop Now
Improve your vehicle's ride. Add a Firestone air spring kits and air bags level your truck, reduce/eliminate vehicle sag and sway, and give you an overall smoother, safer ride. Available for vehicles with coil spring and leaf spring suspensions.
Chevy Firestone Air Bags
Dodge Firestone Air Bags
Ford Firestone Air Bags
GMC Firestone Air Bags
Firestone Air Bags for All Makes/Models
Replacement Firestone Air Bags ( they have different brands this just to tell you what they do )
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 11-02-2014, 09:18 AM   #25
Thanks gljurczyk, looked them up and have an understanding now. Something to check into.
Old 11-03-2014, 07:28 AM   #26
Originally Posted by spock123 View Post
I didn't read that Ford said anything. Someone put the lift kit on the Ford and Ford said at the bottom if you put the lift kit on and something went wrong then it was not Fords fault
It's underlined. Maybe you need to go back and read it again. Who do you think is saying it? You don't have to like it, but to simply pretend it doesn't say what it clearly says is quite...
Old 11-04-2014, 04:48 AM   #27
Go down all the way to the bottom and see what Ford says about things you add on to the truck.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 11-04-2014, 05:47 AM   #28
I have read the page a few times and I don't see anything underlined but I am a little old and I don't see too good.
Old 11-04-2014, 07:53 AM   #29
It is underlined in my screenshot. If you are going to the link, you won't see it underlined in the actual article. I know of the legal disclaimer at the bottom. I also know that any time I get a cup of coffee it will have a legal disclaimer on it- so I don't give them much consideration. Doesn't change the fact that the article plainly states that he added a 2" lift kit for an additional 5K towing capacity. And this is a Ford Motor Company publication, not just some random magazine article.
Old 11-04-2014, 08:02 AM   #30
That still does not change what Ford says
2013, cedar creek, weight
