Old 03-28-2013, 07:58 PM   #1
Cedar creek 36b4 ice maker issue
Hi all i just got my new cedar creek 36b4 and love it. I have not been able to figure out how to turn the water on to the ice maker in the electric only fridge. Any one run into same problem?
Gordo is offline   Reply With Quote
Old 03-28-2013, 09:02 PM   #2
Our fridge (residential) is in the slide out and the water valve for the Ice Maker is located outside under the slide - it is a small push/pull valve and you need to push it IN to turn the water on.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 03-28-2013, 09:05 PM   #3
Hmmm thank you for the info i will look in morning i have the same fridge but mine is not on a slide out but maybe still something underneath. Wife would thing i am crazy if i go out with a flash lite and 25 degrees out
Old 03-28-2013, 09:56 PM   #4
Certified Curmudgeon
Gordo,If it is 25* out and you have an exterior water valve in use you
have a problem. Also, the standard slide mounted valve works backwards.
If your fridge is next to your oven, look behind the panel that is
hidden behind the drawer under the oven. If not,
look under the sink for the valve on the supply line. If its not
in one of those places I'm out of ideas.
Mike Dropped
Old 03-28-2013, 10:07 PM   #5
Full Timer
life2short4nofun's Avatar
I also have the 36b4 it is under the stove pull the drawer out below it and you will see it back there
Ford Western Hauler
2013 CC 36B4
life2short4nofun is offline   Reply With Quote
Old 03-29-2013, 05:00 AM   #6
Thanks for the info i thought if i kept the heat on and the tank heaters on it wouldnt be a problem to have water on below freezing? It is warming up here in thup of michigan now suppose to get freezing at night any more 50 during the day thanks again
Old 03-29-2013, 08:46 AM   #7
Found it underneath stove when i turned on it leaks some where behind fridge so add that to list to bring in
Old 03-29-2013, 09:06 AM   #8
Unfortunately, that's not unusual. They either pinched the plastic supply line on installation or did not correctly tighten the
compression fitting. I know of one 36 series owner that installed an access door
so he could blow out the line or change
the solenoid valve. A bit extreme for me.
I'm one of the lucky ones with no leak.
Mike Dropped
Old 03-29-2013, 11:13 AM   #9
yes on the 2013 CKTS the valve is on the outside of the slide, totally unprotected fro the temperatures, seems CC still has some engineers that don't think water freezes, mine froze and split on our last trip.
bob34787 is offline   Reply With Quote
Old 03-29-2013, 11:24 AM   #10
Mine is on the inside and protected but I wonder when they winterized it if they did it all the way threw the ice maker? It goes in on monday for some other things so I guess we will see
Old 03-29-2013, 12:13 PM   #11
Factory winterizing is air. There is no actual water test so no pink stuff. Don't
know about yours but my icemaker supply line has a drain. The good news is that I will probably never use it cause I don't winterize.
Mike Dropped
Old 03-29-2013, 11:54 PM   #12
textman's Avatar
I just cut the water off going to the fridge and let the ice maker cycle a few times. This pumps the water out so you don't have to run anti-freeze through it...
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded
Loving Life
textman is offline   Reply With Quote
