Old 09-22-2013, 11:34 AM   #11
rattleNsmoke's Avatar
Ducks like cold water......
rattleNsmoke is offline   Reply With Quote
Old 09-22-2013, 02:20 PM   #12
Former Full Timer
Duckogram's Avatar
Indeed. And they don't heat hot water either.... LOL
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 09-22-2013, 02:40 PM   #13
jerseyboy's Avatar
They would have hot water if you taught them to turn the switch on at the water heater.
jerseyboy is offline   Reply With Quote
Old 09-22-2013, 05:38 PM   #14
Originally Posted by Duckogram View Post
The switch located on the control pan behind the burner tube is the only 110v
switch on the Suburban SW water heaters.
Turning on AC power via the pedestal or generator will not automatically switch the water heater to 110v operation. You must
manually turn the switch on to get power to the heating element. This is to prevent the heating element from coming on when there is no water in the heaters tank.
I have also found no useful purpose for a hot water heater in any of my RVing experiences.
I'm going to have to look at my water heater again. What you explain above makes a lot more sense. Sorry if I caused any confusion.
2014 CC 34RLSA
2013 RAM 3500 Laramie CC SB 4x4 CTD
sidney is offline   Reply With Quote
Old 09-22-2013, 07:12 PM   #15
Former Full Timer
Duckogram's Avatar
Sidney,
If your 110v water heater element is coming on with the switch Off, your switch may be fused. This could be possible if you plug into a hot pedestal with the switch on or it could be a defective switch.
You could put a meter on the element and, with the switch off, determine if there is current. If there is, you will need a new switch... under warranty of course.
Hope this helps.
p.s. just pulling your leg about the hot water heater thing. LOL
p.p.s. the Suburban will run with both gas and 110v simultaneously. I do this occasionally when I want hot water immediately after my DW indulges in a Hollywood.
Old 09-23-2013, 05:50 PM   #16
Ducky, I've heard of a 'Navy shower'. I've taken plenty of those in our old TT with the 6 gal water heater but not a 'Hollywood'. Is it the polar opposite?
Old 09-23-2013, 06:33 PM   #17
Former Full Timer
Duckogram's Avatar
Why yes it is.
Quote from: en.wikipedia.org/wiki/Navy_shower
The United States Navy phrase Hollywood shower contrasts with navy shower, and refers to long lavish showers without limits on water usage.[3][4]
Old 09-23-2013, 07:00 PM   #18
Ahh.....gotcha. Inquiring minds wanted to know...
Old 10-01-2013, 01:34 PM   #19
We too sometimes run both the gas and electric heaters for faster recovery, although normally I leave the gas off. It took me a few fumbling tries to figure it all out. The DSI switch to start the gas heater is in the control panel inside the trailer in my unit. When I set up, I run water from any hot water spigot in the trailer to be sure the tank is full, then I turn on the switch in the heater compartment. When leaving I switch it off. I don't drain the tank though. Should I?
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
Old 10-01-2013, 04:41 PM   #20
Former Full Timer
Duckogram's Avatar
That depends on whether or not you will get a hard freeze and how long it will be sitting without being run.
The freeze goes without saying. The length of time sitting is a guess. You could get a mineral deposit issue or a mold/slime situation. It depends on the quality of water in the tank and the condition of your system. Mine sits for 8 months under Palm trees so mold is my biggest concern. Since I'm way farther south than you, it never hard freezes so I never winterize. I just flush and sterilize before we head North.
cedar creek, converter
