Old 10-05-2015, 12:40 PM   #1
Cedar Creek 36CKTS water tank
Good afternoon
We purchased a 2105 Cedar Creek 36CKTS last year, the first time we used the on board fresh water tank, it Blew out the outlet fitting on the bottom of the tank after we filled with water. We cared it back to the dealer and they repaired it. We don't use the tank except one time per year, the rest of the time we are connected to city water.
We got ready to leave this year to use the Fresh water tank, Filled it up and again it blew out the outlet fitting on the bottom of the tank. Has anyone had this problem and if so what is causing this?
Haroldm is offline   Reply With Quote
Old 10-05-2015, 03:00 PM   #2
Former Full Timer
Duckogram's Avatar
Not sure exactly what an "outlet fitting" is? If you are talking about the plastic drain valve/petcock, then yes, they break. Most likely cause is freezing temps and no antifreeze in the FW tank. Another possibility is that your overflow vent is blocked. That would cause a pressure buildup that could cause your issue. When you fill the tank does water run out of the overflow?
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 10-05-2015, 03:05 PM   #3
The outlet fitting would be the supply line from the tank to the water pump. It is not freezing, both times it has done this it is above 75 degrees.
Yes water ran out the overflow tube. Then the pressure from the tank being full cause the supply line on bottom to blow out the bottom of the tank.
Old 10-05-2015, 03:17 PM   #4
dieselguy's Avatar
Who knows what the dealer did to repair your tank ... Are you sure it is the fitting itself or did the hose just blow off the fitting? The hose is held on by a PEX crimp connector. The fittings and bosses cemented to the tanks are all plastic. If the threads are gone and all they did was wrap a bunch of teflon tape around a new fitting ... you know the result. Sometimes the vent line is kinked and as you fill the tank up via the fresh water fill valve, pressure builds up and the tank enlarges. You usually get a noticable bulge in the floor when this happens as the tank swells up inside the frame under the floor. I'd guess what I eluded to at the beginning ... the fitting was stripped out at the factory and the tech half a__ed it. Installing a new tank isn't that hard ... I did on my brand new Silverback 2 months after I got it. The tank was cracked above the outlet fitting. I don't trust dealer techs and had the tank delivered to my home straight from the CC factory warranty division.
dieselguy is offline   Reply With Quote
Old 10-05-2015, 03:28 PM   #5
Yes the fitting is still attached to the line and looks like it was glued in. The Plastic covers on the bottom of the tank are bulged out. The vent line was draining when I reached max fill but not a lot.
Old 10-05-2015, 05:14 PM   #6
Former Full Timer
Duckogram's Avatar
Some pics might help to communicate your issue.
Old 10-05-2015, 07:29 PM   #7
CCRVOC
Ramblin Recks's Avatar
I stop filling my fresh water tank when the overflow (vent) begins "flowing". I never have the water supply spigot all the way open to try to prevent an over pressure in the tank. Nor do I trust the tank sensors to tell me when it is full. So far so good.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 10-05-2015, 08:04 PM   #8
No issues with mine.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 10-06-2015, 07:58 PM   #9
I , have heard the vent line from the tank wont handle the flow from filling ,we put in about 10 gal at a time so havent had a problem. maybe try filling at 1/2 rate?
Big Bill is offline   Reply With Quote
Old 10-07-2015, 07:39 AM   #10
dieselguy's Avatar
Big Bill ... the vent line is 1/2" as is the fill line. The problem lotsa times is the vent line is kinked over itself during installation ... mine was and secured with a wire tie to boot. A mobile repair guy in my area brought this up in conversation.
cedar creek, tank, water, water tank
