Old 11-19-2018, 05:03 PM   #1
Mddle of the Rd Extremist
MeepMeep's Avatar
Cedar Creek 38FL Black tank valve finally bit the dust
Thank goodness itís stuck open and I can use the add on blade valve for dumping for now. What kind of repair bill should I expect, as I canít do the job myself?
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 11-19-2018, 06:48 PM   #2
SilhouettePenny's Avatar
How competent is your local dealer!
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 11-19-2018, 06:53 PM   #3
MeepMeep's Avatar
We’re full timers so we don’t have a “local dealer”.... which is the reason I’m looking for a ballpark figure for the repair BEFORE I call in professional help. Thanks
MCPO (Retired)
Old 11-19-2018, 07:38 PM   #4
NMWildcat's Avatar
Depends on the hourly rate in the area you are in. Also depends on how long the cable is and how hard it is to get to.
Seems most hourly rates in our area are $135 to $185. I would think a two hour max, perhaps one hour. If a mobile service, maybe a service call fee also.
So hopefully under $200 for the job. Usually estimates are free.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 11-19-2018, 08:09 PM   #5
MeepMeep's Avatar
Thanks for the feedback.....
MCPO (Retired)
Old 11-19-2018, 08:33 PM   #6
gkochel's Avatar
First.... thank you for your Service Master Chief ! Secondly I had 3 valves replaced at one time by my local Camping World for $350. Figured I would get them all done while the belly was opened up. Make sure you DO NOT get the twisted wire cables as they do not last, solid cable is what you want.
2015 Cedar Creek 34RLSA Touring
2004 Silverado Duramax Crew Cab Dually
gkochel is offline   Reply With Quote
Old 11-19-2018, 09:27 PM   #7
MeepMeep's Avatar
Thanks for your reply.... serving our country was a calling I shared with my grandfather (Chief Radioman USN), my Dad (Sergeant Major, USA) and my brother (First Sergeant, USA). Thank you for your kind words 🇺🇸
Your response was more than helpful. I didnít know about the difference in cables. Iíd read about the problems with cables being too long, which led to their failures. The repair cost information was very helpful and much appreciated
Happy trails!!
MCPO (Retired)
Old 11-19-2018, 11:15 PM   #8
gkochel's Avatar
You are very welcome and good luck!
USAF SSGT and ANG as a young man. Father USA and USAF and his father USN. My Sister and her husband USA. Happy post Veterans Day and have a great Thanksgiving sir! We do have much to be thankful for.....
Old 11-20-2018, 09:37 AM   #9
DKRITTER's Avatar
All 3 of our valves were a PIA since day 1. One finally broke last Christmas, like you luckily it was open. Since they leaked from day 1 we had a twist-on valve already so we were able to get by till we got home.
The issue was the cables were all way to long so the were wrapped/looped in the underbelly. They were actually twisted cable so pushing the valves caused them to expand. We found the actual valves worked pretty well but decided to start fresh and just do it the way it should have been done in the first place.
We replaced the plumbing and changed all the valves to Valterra solid cable valves and haven't had any issues.
Not sure how much we spent but it was at least a few hundred on valves, black pipe and fittings. We did the work ourselves which I would guess saved us $300.00-$500.00 in labor. If I had someone do all this I would have budgeted about a grand and would have been very safe.
An alternative is only replacing the cables. Valterra sells solid wire cables and if you can get to the valves you can or have someone properly measure and cut the wire correctly then install them onto the existing Bristol valves. Parts are about a hundred and labor guessing 2-300.
https://www.amazon.com/Valterra-TC72...valterra+cable
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is online now   Reply With Quote
Old 11-20-2018, 12:02 PM   #10
I had my tank valves replaced by Orvan Fry, free, under warranty. The black water tank valve had never worked
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
black, black tank, cedar creek, tank, valve
