Old 05-10-2014, 09:39 AM   #1
jkaspar20's Avatar
Cedar Creek 40 CCK
My sister has just took delivery on a 40 CCK (2015). On the control panel there is a switch labeled "slide room" on/off. Can't find documentation on what it is connected to or what it does. Can anyone shed light on this.
jkaspar20 is offline   Reply With Quote
Old 05-10-2014, 09:56 AM   #2
Oakman's Avatar
On my CC Silverback it disables the switch next to it labeled "slide room" in/out.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-10-2014, 10:05 AM   #3
Plain Old Member
Same here. Disables slide in / out switch.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-12-2014, 07:12 AM   #4
Same on our's... :-)
Truck 2009 GMC 2500 HD,D/A,Ext.Cab,SB,air bags, lift kit, flow gate, etc.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
Camping Day's: 2012:25,2013:27,2014:38,2015:38
Little John is offline   Reply With Quote
Old 05-12-2014, 10:33 AM   #5
have the CCK as well and I echo everyone's replies.
2014 Cedar Creek Cottage 40CCK
stever40 is offline   Reply With Quote
Old 05-18-2014, 09:53 AM   #6
puff's Avatar
Same as above.....it is like a lock out switch to prevent accidentally moving the slide.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 08-24-2014, 07:27 PM   #7
jkaspar20's Avatar
My sister is planning to winterize her cottage come November. We can do the normal winterizing except:
The frig, there any instructions on "How To" winterize the ice maker since this unit has residential frig.
also the dishwasher
Old 08-25-2014, 07:22 AM   #8
When traveling I always turn the slide out switch to OFF. Prevents any possible mishap from accidentally pressing the switch when messing around inside our panel box for keys, water pump switch or whatever! 😜
SilverbackMel is offline   Reply With Quote
Old 09-02-2014, 11:19 AM   #9
also the dishwasher
I am a rookie at the ice maker and dishwasher as well. Hope someone can chime in.
Old 09-02-2014, 04:47 PM   #10
I don't have the dishwasher on my 38FL, but the residential fridge has drain line and water turn off under the slide out. Also, lift the bar inside the freezer to turn it off. Last year I just ran antifreeze into the icemaker and I still had the PLASTIC chamber on the ice maker solenoid burst. Since I don't use the icemaker anyway, I replaced the solenoid, but did not reattach the water line. Instead, I attached a push connect valve ( Mur-Lok RO-Pal - Pipe x Push Connect - Bulk Reef Supply ) to the water line so I can winterize without running antifreeze to icemaker.
Would hope that the dishwasher has the same type of shut off set up.
Good luck. ( you do NOT want to pull that fridge out )
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
cedar creek
